Knocking noise after figs lca install
Old Jun 11, 2018 | 07:39 AM
05ls430518's Avatar
05ls430518
Default Knocking noise after figs lca install
I was wondering if anyone else experienced any knocking after installing the figs lcs billet bracket and bushing, it happens over bumps.
Old Jun 11, 2018 | 08:29 AM
Romanova's Avatar
Romanova
I don't have those, but here is what I would run through...
Everything tight and torqued to spec?
Is it (the noise) on both sides or just on one side?
Are you sure it's from the LCA and not something else? Try jacking each side up and seeing if the wheel has any play in it?
You have to remove the dished washer plate when you install them... wouldn't be from that, would it?
Run through the basics first and report back or trying reaching out to Figs. For the price they want for their LCAs, you shouldn't have any knocking noise...
Old Jun 12, 2018 | 01:33 PM
Mbodall's Avatar
Mbodall
Was this noise not present before swapping the LCAs?
Old Jun 13, 2018 | 08:11 AM
05ls430518's Avatar
05ls430518
I am curious if its normal I also have the figs upper control arms as well. I will be shooting FIGS an email and see if they can help. Maybe its cause the control arms and bushings are solid so its just gonna be louder maybe? I am gonna jack the car up today and check the wheel.
Old Jun 13, 2018 | 09:15 AM
LSKelvin's Avatar
LSKelvin
Go back and check torque on everything new. When I put on my UCAs I had to retorque 3 times before everything stayed tight.
Old Jun 13, 2018 | 10:40 AM
ls430w140's Avatar
ls430w140
Are you referring to lower control arms issue or upper control arm issue? Knocking may be the result of poor installation and loose bolts holding the suspension. Sadly to say you may want to reset it all on the ground, uninstall bolts and torque everything back to specs. If issue is persistent, please send the picture of upper control arms in the position when wheels are on the ground.
Old Jun 13, 2018 | 10:42 AM
ls430w140's Avatar
ls430w140
You are absolutely correct with UCA. I had to do it too.
Old Jun 13, 2018 | 03:45 PM
05ls430518's Avatar
05ls430518
Everything is fine no movement in the rim when wiggled, you can physically hear the balljoint clunking. I am gonna email figs tonight. This sucks.....
Old Jun 13, 2018 | 08:36 PM
Catalina45's Avatar
Catalina45
Did you re-torque the bolts & determine there was no change? Secondly are the sway bar end-links tight? I ask because I was helping my neighbor diagnose a clunk in the suspension of an ‘06 Mustang. Turns out in order to stop the clunk I used some Nord-Lock washers on the end links. I had spare washers after needing them to keep the front-end alignment on a street vehicle I open road raced. They are commonly used in aircraft, racing & industrial applications. My buddies Pro Optima Series car used them until he could exceed 1.4 g’s road racing(then he had to have billet alignment plates CNC’d) so I suspect the wildest slammed LS430 will never generate the type of force necessary to break the torque holding ability of the washer.
Old Jun 14, 2018 | 04:47 AM
05ls430518's Avatar
05ls430518
I checked everything and its all tight and tq to spec, the ball joint is just making noise its bummen me out =(.
suds
Suspension and Brakes
Sep 8, 2016 06:17 PM
pinoiryder
Feb 7, 2011 09:50 AM
Higgo
Jul 22, 2008 07:15 PM
EnzoRX
RX - 1st Gen (1999-2003)
Dec 27, 2002 04:31 AM
