Broken Driver's Seat Bracket
Old May 14, 2018 | 07:38 AM
hklinker's Avatar
hklinker
Default Broken Driver's Seat Bracket
This morning, while leaning back to get my wallet from my back pocket, I heard a crack and the front left side of the seat broke loose. Not the bottom part (the track bolted to the floor), but the part that is attached to the bottom to the seat. I raised the seat to find the bracket holding the seat (made of pot metal) cracked off. I've attached a photo that shows the bottom of the bracket.
Now that I know what the problem is, I need some advice on how to remove the seat and replace the bracket. Since everything now is wired to the SRS, I don't want to set off airbags or cause error codes. Can anyone help me with this?
Thanks, Herb
Old May 19, 2018 | 08:12 AM
hklinker's Avatar
hklinker
UPDATE:
The cost to replace the seat sub-assembly is $1800. I found a welder who can replace the seat, but I have to remove it and take it to his shop.
I need guidance on how to safely disconnect the SRS sensors so that I don't set off the airbags or end up with an SRS error code.
I will disconnect the battery before starting. Is there anything else I need to do?
Thanks,
Herb
Old May 19, 2018 | 08:51 PM
05ls430518's Avatar
05ls430518
Disconnect the battery and let it sit for an hour so the airbags can discharge.
nuraman00
Feb 14, 2017 07:04 PM
AlblineLex
IS - 1st Gen (2001-2005)
Feb 5, 2014 01:42 AM
jwminzen
Dec 16, 2013 07:41 PM
lexitaxi
RX - 1st Gen (1999-2003)
Jan 7, 2010 08:57 AM
nsxmod
Nov 18, 2009 11:20 PM
