I have a 2004 LS 430. The VSC, Brake, Check Engine light coming on occasionally. Mechanic unable to diagnose unless lights are on when I bring it in. This has occurred before and after battery failed and was replaced, it went away for 3-4 months. Lights are coming on again and battery sounds like it is weakening. Any ideas out there?
05ls430518
close
- Join DateNov 2017
- LocationNew York
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:267 Times in 222 Posts
Quote:
Maybe your alternator is on its way out, your mechanic test it to make sure you its charging the correct amountOriginally Posted by azbullpro
Get yourself a code reader. Bought one for less than $30 from Amazon. Then you will get a much better idea as to what the problem is.
