Will these fit our LS430?
Old Mar 23, 2018 | 09:29 AM
KingLS's Avatar
KingLS
Default Will these fit our LS430?
Would love to steal (figuratively) these wheels from this guy on Craigslist (I know!!) to use as my winter set... they seem to fit the criteria, but not sure. And yes, I'll be covering that shamefull hyundai emblem!
2012 Hyundai Sonata Limited OEM 17" x 6.5" aluminum wheels with nearly-new 2014 Bridgestone Blizzak WS80 winter tires in P 215 55 R 17 size. The wheels are 17" diameter x 6.5" wide. They are 5 lug on 4.5" (114.3 mm) bolt circle pattern with 46 mm offset. Hyundai Part Number for the wheel is 52910 3Q250. Cross Reference to Hollander Wheel Part Number 70803
Old Mar 23, 2018 | 10:44 AM
05ls430518's Avatar
05ls430518
I highly doubt it it probably will not clear the front brakes, the rims are 6.5 the stock ls430 rims are 7.0 stock.
Old Mar 23, 2018 | 12:27 PM
KingLS's Avatar
KingLS
thanks, a lot of good info there...but I'm looking for someone with a little more certainty
Old Mar 23, 2018 | 02:24 PM
NL5's Avatar
NL5
Yep, just make sure they will clear the brakes. Only a very small percentage of wheels will clear. I ended up with Works, but had to run a spacer. Most likely would need one with the wheels you are looking at.
Old Mar 24, 2018 | 01:19 AM
Scootymad's Avatar
Scootymad
If they don't clear the calipers, just get some spacers to clear them. I wouldn't go more than half an inch but I've seen plenty of 1 inch spacers used.
I do know for a fact that FD RX7 16s will fit on the rear with a thick black Mediterranean one of clearance for the caliper
fittdogg
Dec 15, 2017 08:21 PM
Jla1976
Oct 18, 2017 07:40 PM
IowaVol
May 8, 2011 08:19 PM
V8_Fan
May 16, 2010 08:08 PM
c5mtl
Oct 31, 2006 05:31 AM
