How to remove front sway bar?
Old Feb 24, 2018 | 08:27 AM
05ls430518's Avatar
05ls430518
Default How to remove front sway bar?
Does any one have a link or any knowledge on how to remove it? I could not find anything on removing the actual sway bar there was only endlink and bushings removals.
Old Feb 24, 2018 | 09:37 AM
2KHarrier's Avatar
2KHarrier
Here's direct from the manual..
Not very informative at all.
  1. REMOVE STABILIZER BAR FRONT
    1. Remove the 4 bolts and stabilizer bar front.
    2. Remove the bracket and bushing.
After removing the stabilizer link and bushing bolts, not sure what else holds it in place
Old Feb 24, 2018 | 09:44 AM
05ls430518's Avatar
05ls430518
I was wondering about all the plastic and stuff, I dont want to just start yanking and prying at the plastic and break something
Old Feb 24, 2018 | 10:27 AM
pmesfun's Avatar
pmesfun
First you have to remove the big lower splash shield. Then there two smaller ones parallel with the wheels attached to the left and right frame rails right on the outside of the sway bar brackets. After removing the brackets and links the bar should drop down. Most of the hardware is just 10mm bolts, I would take pictures to remember where they go.
Old Feb 24, 2018 | 10:58 AM
05ls430518's Avatar
05ls430518
Awsome thank you very much for your help, when I do my sway bar I will take pictures and post them.
2KHarrier's Avatar
2KHarrier
Oh,yeah, you have to remove the splash shields first, and then you can pull the stabilizer bar..
Old Feb 25, 2018 | 02:15 PM
05ls430518's Avatar
05ls430518
I guess thst means I need to do a write up for it lol I will also be doing a write up for the lca bushings, the figs one are completely different and do not have to have the suspension cycled or preloaded.
Romanova
May 7, 2018 07:46 AM
situman
Jul 5, 2016 08:20 AM
RXGS
May 18, 2016 04:45 PM
Scott1258
Suspension and Brakes
Jun 23, 2007 09:49 PM
