Common suspension wear items
https://www.ebay.com/itm/FACTORY-OEM...xaFkG8&vxp=mtr
Just to illustrate how bad the Lexus dealer was, I asked, "Would I fail a state inspection because of that?" They said maybe. And the reality is., no way. I can't imagine being treated like that on a new car, where they try to recommend unneeded repairs for their commission. Contrast to BMW, they suggested thrust arm bushings which are the equivalent, but said you don't have to do them to pass inspection, just wanted to bring it to your attention that they are showing physical wear.
Are you driving an Ultra with air suspension? It's a totally (potentially) different conversation if you're driving an Ultra.
New shocks and an upgraded set of anti roll bars are what you need. The pissant rear ARB in these are pretty hopeless. My Ford Contour had a thicker ARB and that wasn't overly large in the grand scheme of things. I think Ultra Racing do larger bars and chassis brace kits
lexus is great but i really have a hard time believing a 100k mile car has no material wear on the suspension. Arnott now makes front air struts for like 500 a piece, if they do a rear, I would be sorely tempted to just replace the entire suspension front and rear. I'm DIYer so the cost isn't so crazy and it would be interesting to see the effect.
by the way, the number of used air struts on ebay is amazing, many from Japan which means low miles. I'd bet the price will start to fall big time..
I have all the ultra racing products only 1 is installed on my car right now the rest will be installed when it gets warmer.
Most people do the oem sport suspension sway bar upgrade and are fine, i would start there the ultra racing sway bars are huge and will change your ride comfort dramatically. I have to look at them but its 28mm front 19mm rear if i am not mistaken, this will also drastically change how your car handles as well so keep that in mind.
- Hub centric rings are usually not something that is required to have on LS.
- Wheels need to be torqued to a hub using right tools and right method to prevent vibrations from this source. Use hand to manually tighten all five bolts to ensure rim is centered, then apply 76 ft lbs torque from your torque wrench. Your wheels will be centered (if your lug nuts are good)
——- Tires need to be force balanced. This is a must on this car.
——- Tires should be made by reputable brand. Cheap tires will cause wandering, vibration, instability during turning, and excessive noise. Poor alignment will aggravate it.
—— Worn wheel bearing may either cause a clunk during turns, or trolley bus noise while accelerating, or “Low Tire Warning” if one of the tire takes significantly more effort to rotate than the other.
—— Old original ball joint or cheap aftermarket LCA ball joint will affect suspension performance as it may not function properly according to Lexus standards. Now, in case if this element fails under heavy load, the consequences will include body damage.
—— From my experience, upper control arms are subject to a tiny wear even after 100k miles compared to lower control arms.
—— What dealers never do to our LS, is verify the condition of steering rack mounts. I ve seen cars that had a problem with moving steering rack under pressure. It will cause floaty steering.
Let me know if you find any of this information useful.
