Ls 430 consuming too much fuel
Old Jan 15, 2018 | 08:50 PM
Safeer69's Avatar
Safeer69
Originally Posted by semar
Smelling fuel under the hood - bad mileage
Had a problem with that on my old 735i. No visible leak but strong fuel smell. Turned out to be a pinhole in the fuel supply line
Please tell me how did you figure out that pinhole in the fuel supply line?
If there is some problem with the maf sensors or if is it not clean, will the onscreen meter will give me check engine tag or something else to notify me?.
Old Jan 15, 2018 | 09:33 PM
05ls430518's Avatar
05ls430518
It might not give you a check engine light if the maf is just dirty you can use this to clean it
Old Jan 15, 2018 | 10:58 PM
Safeer69's Avatar
Safeer69
are you sure this is gonna work? because i don't wanna experiment and then replace it anyhow later, i don't know what to do now.. let's see will try taking to some other garage. Hope this problem gets fixed
Old Jan 16, 2018 | 12:19 PM
semar's Avatar
semar
when the smell was also noticable in the cabin I took the car to the mechanic who found the location. It was the line going into the fuel rail and the immediate area was unusually clean
Old Jan 16, 2018 | 12:20 PM
ls430w140's Avatar
ls430w140
I can help you make a decision.There is nothing wrong with using CRC cleaners on these two parts unless you are breaking it during removal/installation or actual spray application. It is very very important to avoid using strong chemicals on MAF sensor. Absolutely not. The one that was recommended to you is working just fine.Now, remember, if you MAF sensor is already going through severe aging problem, then the best bet will be to replace it. If I am not mistaken, you can purchase OEM (!) Denso made in Japan sensor on eBay from trustworthy seller for less than 30 dollars. As previously mentioned in other topics, the new sensor does a miracle to 3uz-fe if the old sensor was not effective anymore.
Old Jan 16, 2018 | 12:31 PM
05ls430518's Avatar
05ls430518
I have used them on my ls first hand and they work fine thst is why i suggested it, they are formulated to evaporate off the sensor they are fine and specifically designed to be used on the sensor.
Old Jan 16, 2018 | 04:05 PM
YODAONE's Avatar
YODAONE
How would you identify severe aging problems with MAF sensor as it relates to engine operation...
Old Jan 16, 2018 | 04:55 PM
ls430w140's Avatar
ls430w140
Keep it simple. Let’s say you cleaned MAF sensor with some good chemical, installed it back and it still runs engine rich or lean if confirmed by the scan tool. Or, like what happened in my case, MAF had some dirt on it which could not be removed by spraying CRC. Replacing it solved a problem with idle hesitation and acceleration.
Old Jan 16, 2018 | 08:38 PM
Safeer69's Avatar
Safeer69
Sir, one final question.. Let's say if my maf sensor is faulty, will it notify me on my dashboard screen? and if it's not showing any error message, will the cleaning of the maf sensors be effective?
Old Jan 17, 2018 | 04:30 AM
rkw77080's Avatar
rkw77080
A faulty MAF will give you one or more of the following:
P0100 - MASS OR VOLUME AIR FLOW CIRCUIT
P0101 - MASS OR VOLUME AIR FLOW CIRCUIT RANGE/PERFORMANCE PROBLEM
P0102 - MASS OR VOLUME AIR FLOW CIRCUIT LOW INPUT
P0103 - MASS OR VOLUME AIR FLOW CIRCUIT HIGH INPUT
Cleaning can be very effective if performed properly. There are 2 temperature elements that require thorough cleaning: The Temperature Sensor is located on the side of the MAF probe; and the Hot Wire located up inside of the MAF probe. The Hot Wire is difficult to reach and a random spray of cleaner is not enough to clean off the baked-on contaminates from the hot wire to restore the MAF's original performance. You really need to get up in there (without actually touching the hot wire, of course) with the spray. See diagram below...
Old Jan 17, 2018 | 06:28 PM
jayclapp's Avatar
jayclapp
Driving conditions have a huge effect of "current gas mileage" calculated by the car's computer. For instance, today I pulled up to CVS drive thru for prescriptions. I notice my fuel gage was just slightly below the middle level and the current gas mileage was 17.3. I waited there in idle mode for about 5 minutes and noticed that the current gas mileage had dropped to 17.2. Heavy traffic while driving in town can have a significant effect on the calculated current gas mileage. By the way, I do agree that the cars calculate "current gas mileage" if acceptably accurate compared to calculations using actual distance and gas consumed when filled up.
Old Sep 30, 2020 | 01:27 AM
F16uae's Avatar
F16uae
Hi guys, i own a ls 430 of the year 2002,
Recently while driving i faced an accelration problem, whenever i pressed the accelerator the car didn't accelerate as it should and it would give me a petrol smell. With that i noticed my petrol guage is decreasing really fast. My range approx decreased 2 km on every half km.
I showed my car to the garage and he cleaned all its fuel filters, catalic, but nothing changed, after that he changed the knock sensors which worked with the acceleration, however my car is consuming the same amount of petrol.
Please can anyone help me with this problem because i cannot pay everything in the gas or to the mechanic.
i am seeing the same issue with my car how did it fixed ??
Old Sep 30, 2020 | 01:37 AM
Safeer69's Avatar
Safeer69
it's either the ECU or the sensors, you can use an OBD scanner before consulting to a mechanic, they might squeeze your wallet to earn every penny they can.
Could be a single problem or a number of problems, this is a vast issue which needs a proper LS specialist.. for the starters do try a fuel injector cleaner - might be the debris in your tank (hopefully)
Old Sep 30, 2020 | 01:44 AM
F16uae's Avatar
F16uae
i have done all the things you did changed plugs , coils , injectors and changed maf and cleaned TB i get o2 sensors codes But how is it possible that All 4 o2 sensors can go bad at once so could you tell me how u get it fixed so that i could try it
Old Oct 1, 2020 | 08:11 PM
YODAONE's Avatar
YODAONE
Cleaning an aged MAF sensor does not always restore full function. Resistors degrade with age. Some like to clean their MAF immediately after running. Unsure temperature of MAF resistors, but resistors tend to heat up and so spraying cold MAF cleaner on sensor resistors creates issues.
After 180,000 miles, cleaned MAF on 1999 LS400 to clear trouble code...
Highway mileage was good, however, decided to replace it with an OEM part..about $200. LS430 is about $100.
Immediately noticed improved part throttle response AND City efficiency improved noticeably.
Do not have exact figures to compare or share, but it was definite improvement.
As an interim step have an engine technician check engine vacuum readings at various RPMs...this should tell you whether your catalytic converters are clogged.
