Missing 6th Gear
Old Jan 7, 2026 | 07:51 AM
white_lx's Avatar
white_lx
In case anyone runs into this problem: another undocumented (?) fail-safe scenario is that in case of a knock-sensor code, the transmission will not shift into higher gears. Just experienced this on a 2005 LS430 with P0328 knock sensor code (bank 1). Transmission would not go higher than 4th gear. Not a single ATM code. It was also impossible to shift up manually or use switch to 5th or 6th gear using bi-directional Techstream active tests. After temporarily fixing the knock sensor code by a sensor 1 -> sensor 2 bypass, the transmission started shifting normally.
x10civ
RX - 3rd Gen (2010-2015)
Mar 6, 2012 06:47 PM
outlaws
Jul 3, 2009 07:33 AM
man8959
GX - 1st Gen (2003-2009)
Feb 11, 2007 09:09 AM
koreanpers
Dec 30, 2003 08:54 AM
