Weathertech window visors
Do you know where the wind noise is coming from? Any particular area/window? And have you applied Shin-etsu grease to the seals of the doors and the windows? This may help. I've ordered this same brand for my 4runner, but it's not for noise reduction.
There are some good wind noise threads.
The noise can come from the door seals, the sides of the windshield, the top of the windshield or the front of the sunroof/moonroof. Or a combination.
I put a thin strip of black gorilla tape on the seal on the edges of the windshield. That area is black already and hidden under the overhang. I put a bead of black auto adhesive in the gap along the top of the windshield. Corner to corner.
I put gorilla tape on the inside edge of the sunroof. Extra in the corners. I cleaned all the gaskets. I'm not sure where to buy Shin-etsu grease. Will look into that. Curious of the gaskets are "greasy" after application? Will it rub off on clothing?
I also put gorilla tape (as per another post) on the top of the door seals and inside the door arches.
I essentially covered all the bases and my wind noise has dropped to near zero. I had the gorilla tape and the black auto adhesive, so my cost is just basically time so far.
Lysmau
Apr 23, 2015 08:21 PM
