05 430 vsc abs & trac off
Old Jul 9, 2017 | 09:27 AM
bleudabadi's Avatar
bleudabadi
7th Gear
Exclamation 05 430 vsc abs & trac off
Hi all. I have a 2005 LS430 with just 92k miles and yesterday we went to the flea market. When we pulled in, there was a quick vibration, I thought he ran some rocks over, but in hindsight, I think maybe he hit the brake harder than he should and it slit on the dirt.... well when we went to leave, all of a sudden it says Check System, Check VSC ABS TRAC OFF... didnsome reading and evert thread I saw went in a different direction...gas cap, dirt on sensor, emergency brake, computer.... some tthe mes it comes on when started, other times it waits a block or two...
took it to Autozone and it doesn't throw any codes. Whats more, this morning, the ABS light didn't come on at all...just the other two.
Old Jul 11, 2017 | 09:52 AM
bleudabadi's Avatar
bleudabadi
7th Gear
More info, I have since driven it myself..
the shake that occurs on occasion is when the brake is pressed...the brake pedal itself seems to shake. I'm worried something is loose n the braking system. Since i didn't get the wheel lock key with the car, I need to have the locks removed to get in there and see. God I hope it's nothing serious
Old Jul 11, 2017 | 10:39 AM
imdking's Avatar
imdking
Hopefully the vibration is simply warped brake rotors.
Old Jul 11, 2017 | 11:05 AM
sha4000's Avatar
sha4000
Had the same issue and front rotors solved the problem. I bought back rotors too but I have not out then on yet. Maybe I'll just wait till the old ones were out.
Old Jul 12, 2017 | 04:16 AM
bleudabadi's Avatar
bleudabadi
7th Gear
I don't think it is warped rotors...it only happened a few times, warped rotors would shake almost every time I believe. Also, it feels like something is loose.
after the doctor, i will talk to my mechanic.
Old Jul 12, 2017 | 06:42 AM
Tharper1's Avatar
Tharper1
I don't know if the LS is the same but my daughter has an 03 RX that did the same exact thing you describe. Very intermittent. I tried for several months to replicate what she told me was happening. It turned out to be the sensor ring on a rear axle the the ABS sensor senses was cracked. It's been fixed for a year now, all is good!
Old Jul 12, 2017 | 07:46 AM
sha4000's Avatar
sha4000
The front of my rotor was smooth but once I took them off the back side on the driver's side rotor had lots of grooves and the bottom of the back brake pad was wearing unevenly.
Old Jul 14, 2017 | 06:40 PM
bleudabadi's Avatar
bleudabadi
7th Gear
Well I took it to two different shops, one supposedly specializing in Lexus and nobody can find the problem but today there was a slight grind when backing up with the wheel turned so I'm gonna have a gander at the brakes..I guess you never know...it would be funny if it's because the pads or rotors and the mechanics didn't think about it...nobody's made a dime off me yet except the guy who sold me the car....wonder if it's because his mechanics couldn't find the issue?
ThatGuyJ
Aug 27, 2019 05:06 PM
itzjake
GX - 1st Gen (2003-2009)
Feb 27, 2015 06:46 PM
mercado
Suspension and Brakes
25
Dec 29, 2014 06:27 AM
uMulla
Sep 10, 2012 05:03 AM
RefinedGS
Feb 25, 2004 02:39 PM
