Overheating Issues
Old Mar 8, 2017 | 03:37 PM
rkw77080's Avatar
rkw77080
Originally Posted by 911LE
Do you have any residue on the underside of the oil fill cap? Smell coolant in the exhaust?
Besides coolant leakage into the motor oil and combustion chamber, as 911LE described, it can also leak into the transmission fluid.
Old Mar 8, 2017 | 04:59 PM
911LE's Avatar
911LE
Correct. And if that's the case then only the radiator needs to be replaced. Usually it is the other way around and there is trans fluid in the radiator as that system is at a higher pressure.
Old Apr 17, 2017 | 08:35 PM
js058515's Avatar
js058515
When you replaced your thermostat, did you orientate the jiggle valve on the thermostat at 12 o'clock? I am not sure if this in even necessary, but I just changed my t-stat and I didn't pay attention to where I placed the jiggle valve. I have been having overheating issues and have been trying to troubleshoot it. I read something in the older gen forum about the jiggle valve placement so I thought I would ask.
Old Apr 18, 2017 | 08:40 AM
jazzwine's Avatar
jazzwine
I know that is an important issue and should be done, but my problem was the fact I should have added coolant/water when the heater was on full blast. I just had an air bubble and a failing passenger side radiator fan motor.
Tom in Dallas
Bocatrip
Apr 2, 2016 06:45 AM
bigmitch
Aug 8, 2011 08:08 AM
olddog
Nov 22, 2008 09:28 PM
Lexus082
Nov 27, 2007 01:31 PM
jgm
Aug 17, 2007 08:39 PM
