First oil change today
Old Nov 6, 2016 | 02:21 PM
Johnhav430's Avatar
Johnhav430
Default First oil change today
Went about 2,400 miles on the new car dealer's change, and wanted to get some synth in.
Not familiar with the central jack point, and one can't just crawl under to see, so I used the scissor jack with a jack stand
opened up the panel, rather bent it forward (BMW has a trap door that is hinged, imho the German way is better). Replaced a NAPA select? filter with a WIX XP
had Mobil 1 laying around, time to pour it in--I measured only 4 3/4 qt. out, so I poured 5 in rather than 5.5
edit: btw removed the old drain plug gasket which was stuck to the pan--it seemed to be metal with some rubber or something, where the rubber had totally deteriorated. Had a 10-pack of OEM which are blue and seem to be made of metal. Pack said "Made in Japan." 90430-12031
As far as the central jack point goes, the plastic must come off to get to it, right? Because I saw a circular indentation on the plastic, but felt it with my hand and it's not square on the subframe. I think that this point would be ok to hit with the floor jack? It's also on the subframe and exposed, but would lift one side, not both wheels
hmmm is that dampness on the steering rack? Won't know until next time, but will watch the ps fluid...
I noticed that on my right side, the splash guard if you will that's in front of the tire, is missing. I'm sure the previous owner had some sort of mishap as the right front bumper is scraped there.
Unfortunately, I can see the screws that hold the underside apron are stripping their way into the whachamacallit, they don't fully tighten, but do hold the plastic. On my Maxima, eventually, they stripped and the plastic fell off....
btw is the "information" on the NAV the same as the maintenance reminder? I put today's date and 5,000 miles (don't really go any further with synth, but prefer it nowadays to dino juice)
The LS430 oil change is no longer a mystery....woohoo! Feel better knowing for sure what's in the crankcase....imho our cars deserve this
Old Nov 6, 2016 | 07:07 PM
Gronemus's Avatar
Gronemus
Thanks for the part number. Stopped at a local Toyota dealer the other day wanting to get these and the young man at the parts department said that they did not have access to the Lexus database and could not tell me what the part number was.
What's strange is if I go to Amazon with that part number it tells me that it doesn't fit my vehicle???
I need to crawl under mine to confirm that jack point. The manual's drawing wasn't all to informative. I might just take a can of fluorescent spray paint with me to mark the spot to make it easier to see from the front of the car.
When you startup your car tomorrow you will get a friendly message to change your oil again. The date field is when the maintenance is due next, not the date that it was performed. DAMHIK...
Old Nov 7, 2016 | 06:10 AM
Johnhav430's Avatar
Johnhav430
haha so all it is is a reminder...it was red today. I was expecting to see it on the dash, not the nav screen.
Let us know what you find on the center point, there is a youtube out there (strange I think only 1?) showing it.....also the washers fit the drain plug perfectly. I also got an extra Dorman drain plug with washer--though it's a different material....I think it's possible to get away with not changing it, but it's cheap enough to add to the cost of the job....
edit: apparently there are service, tire pressure, and ac filter warnings.
This one worked, I found a bunch that are incorrect, not sure if for other Lexus:
https://www.clublexus.com/forums/ls-...red-reset.html
When I did the reset the message was very brief: check VSC (I hope that's normal, did not have a problem earlier today), then "mileage reset" flashes so quickly, you're likely to miss it. This displays on disp 1, where I usually show avg mpg.
also found this, and the first is correct, not sure about the tires and a/c filter:
http://us.lexusownersclub.com/forums...ghts-on-ls430/
I guess in 2006, this stuff was very primitive. The nav reminder is nothing more than that, I guess.
td11283
Dec 30, 2013 10:17 PM
underway
Jul 13, 2009 06:47 PM
LexusIS-TL
Mar 2, 2008 12:00 PM
myes350
Feb 26, 2008 06:46 PM
fred430
May 31, 2006 09:15 PM
