Sticking Caliper Piston
Old Aug 19, 2016 | 08:11 PM
Arcturus's Avatar
Arcturus
Default Sticking Caliper Piston
Has anyone here had a sticking caliper piston? Can you repair it with the caliper overhaul kit? Or do you need to replace the calipers?
Old Aug 20, 2016 | 06:39 AM
2KHarrier's Avatar
2KHarrier
You may be able to repair it with a kit, but the piston (part that is stuck) probably will have corrosion around it's periphery, and will no doubt leave scoring marks in the cylinder of the caliper. That may or may not be repairable. For the cost of a rebuilt caliper, I would leave the rebuilding to the professionals, and just swap it out...
.02
Old Aug 21, 2016 | 09:19 AM
Arcturus's Avatar
Arcturus
.02
Probably best is to have a look at it I guess. The repair kit is not expensive and the factory calipers are around $320 USD each.
Does anyone here know what the kit number for the front for an 2003 LS430? Is it 04479-50130? Is there one for the rear calipers as well?
Old Aug 21, 2016 | 10:01 AM
2KHarrier's Avatar
2KHarrier
Lexus kit PN's are as follows;
Front 0447950130
Rear 0447950140
Old Aug 21, 2016 | 08:39 PM
Arcturus's Avatar
Arcturus
Front 0447950130
Rear 0447950140
Excellent. That's what I was looking for!
Old Aug 22, 2016 | 08:56 AM
2KHarrier's Avatar
2KHarrier
My pleasure!
GsLex02
Suspension and Brakes
Aug 9, 2018 03:16 PM
Rubin85
Nov 29, 2016 12:08 PM
co4wheel
GX - 1st Gen (2003-2009)
12
May 4, 2016 09:07 PM
tangopadre
May 29, 2014 06:20 AM
rosswf
Oct 14, 2011 05:23 AM
