Should I Use Fuel Additives?
Old Aug 19, 2016 | 10:49 AM
texan_176's Avatar
texan_176
https://www.amazon.com/CRC-05063-Gua...nateed+to+pass
That is the only additive I have ever seen results with. Every car I used it on picks up 10-20 miles per tank on the treated tank and slightly better mpg on subsequent tanks. I pour in 2 bottles and fill the tank then drive to near empty. It's not really worth it economically speaking since the treatment never pays for itself; it is cheaper to burn the additional gasoline saved by not using the additive. The camera scopes have gotten cheap enough to where you could video the before and after of a cylinder to see if this actually does anything. Some improved MPG is probably due to driving better to induce better mileage so you feel good about buying the additive. In other words you want to see the results you are looking for after spending money on the product.
Everything else from STP, Berryman, Seafoam, etc. has been snake oil in my experience. The Seafoam smoke show where the stuff is pulled into the engine with a brake booster vac line is the worst of them all. Decarbonizing your engine using plain water introduced very sparingly with the same approach is pretty much free and actually works (google it). If you change your oil on time and use quality gasoline this stuff is really not needed at all.
Old Aug 19, 2016 | 01:00 PM
Daspyda's Avatar
Daspyda
Lucas Oil sells a "tune-up in a box" which includes one treatment of valves, etc and three treatments of gas additive.
Old Aug 19, 2016 | 01:11 PM
tradosauru's Avatar
tradosauru
There is definitely money to be made. I'm going to start marketing and selling my own fuel elixir.
LexBrett
Apr 23, 2015 10:33 AM
Nilism
Sep 1, 2012 08:19 PM
anarchyx34
14
Jul 19, 2012 07:33 PM
flektone
Jan 27, 2011 11:35 PM
archangels
RX - 1st Gen (1999-2003)
22
May 7, 2008 05:10 PM
