LS430 Maintenance questions
As for suspension, lowered as it is, I would spend quality time checking and replacing
Ball joints
Control arm bushings
Ball joints
Sway bar bushings
CV joints
Drive shaft support bearing
Brake lines to caliper
Brake pad and rotor
Not suggesting to replace all of the above but recommending you take your time and inspect all of these components. If taking to an indy shop to get work done, you may as well have them do the engine portion of the maintenance combined with a 100% look at your suspension and drivetrain before picking the car up.
Rest assured, no matter what, you will not regret it.
Ball joints
Ball joints
Sway bar bushings
CV joints
Brake pad and rotor
Rest assured, no matter what, you will not regret it.Thread
swilli89
Mar 22, 2018 10:37 AM
