Parking sensor.
Old Sep 12, 2015 | 01:13 PM
Fixman's Avatar
Fixman
Default Parking sensor.
Hi.
Yesterday when parking my 04 in my home garage I got a massage that read "Parking Sensor Fault" withe the front right sensor symbols on the center of tha dash flashing. It did that for a minet then wint off.
I beleve it is the sensor needs replacing. But just whant to confirm that befor I replace it then find out its somthing els. Of cures will be checking the connection to confirm its not lose.
How do you remove it, dos it pup from the front or I need to get it from the back of the bumper?
Thanks.
Old Sep 12, 2015 | 02:08 PM
Fixman's Avatar
Fixman
It's ok found the info I wanted. I did do search 1st but for some reason auto correct was changing what I type so as not getting any hits.
Old Sep 18, 2015 | 04:56 AM
Fixman's Avatar
Fixman
Hi on eBay I got 2 options OEM or not. Not OEM is about 15 $ the OEM is about 50 $. So the question, is the OEM that much beter or both are relatively the same. As I need to get one for the front. Please shear your experience.
http://www.ebay.com/ulk/itm/281691083972
Thanks.
Old Sep 18, 2015 | 05:25 AM
Arcturus's Avatar
Arcturus
[QUOTE=Fixman;9187475]Hi on eBay I got 2 options OEM or not. Not OEM is about 15 $ the OEM is about 50 $. So the question, is the OEM that much beter or both are relatively the same. As I need to get one for the front. Please shear your experience.
[QUOTE/]
At the Lexus dealership near my house, the ultrasonic parking sensors are around 350 CAD each. I am missing a few on my car as well. I suspect both the 15 dollar and 50 dollar version are Chinese knock offs. However that is not necessarily a bad thing. I would pick the one with the most positive reviews or try and find someone on this forum that's bought some from an honest seller.
Old Sep 24, 2015 | 04:44 AM
mikevanle's Avatar
mikevanle
Make sure you get the correct part. I believe there are 2 models depending on which one is bad (center or side ones).
Old Sep 24, 2015 | 05:53 AM
Fixman's Avatar
Fixman
I was going to ask about that. As I found ther is 2 part#. Can you shear the part number and location of each.
Old Sep 24, 2015 | 10:00 AM
mikevanle's Avatar
mikevanle
89341-50011 & 89341-50020
I don't know 100% which is which. The 89341-50011 is described as "corner" and "89341-50020" inner, but there is another sensor on the side.
PilotSmith
Aug 17, 2025 01:28 PM
SMWallis
Jan 22, 2020 12:56 AM
dynamixre
RX - 1st Gen (1999-2003)
Apr 27, 2017 05:51 AM
JDMV8
General Classifieds
Jun 20, 2015 11:03 AM
joshoowa
Jul 16, 2005 02:52 PM
