question about wheel offset
Old Aug 10, 2014 | 01:14 PM
kkasaki's Avatar
kkasaki
Default question about wheel offset
does any of you know if these wheel size will fit a 01 ls 430
18×9.5 with an offset of positive 36
19×12 with an offset of positive 50
Old Aug 11, 2014 | 05:54 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
The first wheel should fit fine depending on your tire size.
The second one won't fit without a ton of fender work.
Old Aug 11, 2014 | 02:56 PM
kkasaki's Avatar
kkasaki
thanks for reply
Old Aug 11, 2014 | 02:59 PM
VerbalKent's Avatar
VerbalKent
x2 on the fender work...but it'd look incredible once done!
Old Aug 11, 2014 | 03:09 PM
kkasaki's Avatar
kkasaki
not looking for more the fender rolling, thankyou
Old Aug 11, 2014 | 10:56 PM
SQuester's Avatar
SQuester
Actually you'll be okay with a 12" +50mm, as it will sit 5mm further inward than my 10.5 +26mm rear setup with just shaved fenders.
Those 9.5 +36mm will be fine on the fronts also with room to spare(depending on ride height and amount of camber).
If anything, you'll run into clearance issues on the inside(rim/tire to suspension), as there will be 43mm less clearance than my rear setup. Might fit, might not on the inside as I haven't measured my inner clearance to give an educated answer.
whytry
Jan 12, 2019 01:06 PM
idoke1
IS F (2008-2014)
Dec 22, 2015 10:53 PM
lol
Wheels, Tires & Brakes Forum
Jun 25, 2013 05:43 AM
boxcarfan
GS - 1st Gen (1993-1997)
14
Nov 2, 2009 03:16 PM
SickSC3
Sep 30, 2004 12:18 PM
