Creaking Noise
Old May 25, 2013 | 09:18 AM
music6890's Avatar
music6890
Default Creaking Noise
My LS430 is so quiet that I hear every little noise.Over certain bumps where the body flexes like over a large speed bump I hear a creaking noise from the doors. I was a mechanic for 22 years and was always good with noises,I have very sensitive hearing. I determined that the noise is coming from the many door weatherstrips the LS has to keep noise out. My 92 LS 400 had the same issue. I have used silicone spray lube which works but doesn't last very long. I have to keep reapplying it and it gets messy. Does anybody have a more permanent, longer-lasting solution? I was even thinking of using a thicker lubricant like a silicone grease but thought it might attract dirt and be messy. Has anyone else experienced this and possibly have a solution. I'm such a perfectionist, I wish I wasn't but it is what it is.
Old May 25, 2013 | 10:25 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
i use dielectric grease.you have to apply it to the top channel the one that the top of the window goes into.there isnt any perm fix for this.
i clean off the old grease and reapply.
everybody uses different stuff but i have been using this grease for over 30 years on my weather stripping.
Old May 25, 2013 | 12:49 PM
music6890's Avatar
music6890
Thanks for the quick response. I was under the impression that it was the large door frame weatherstrips causing the noise. Are you saying it's the one in the window frame making the noise? Also do I get the dielectric grease at a hardware store, Advance Auto?
Old May 25, 2013 | 07:06 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
yes you can get dielectric grease at any autoparts store.buy the big tube and it will last a long time.remember a little bit goes a long way.
get the clear stuff.
USCRugby
Mar 10, 2024 04:59 PM
nokobob
Apr 25, 2011 11:10 AM
rhinotf1
Jun 3, 2009 06:53 AM
wheezemd
Nov 27, 2007 08:52 AM
lkirchner
Sep 9, 2004 05:49 PM
