Key Reprogram
Old Apr 27, 2013 | 12:37 PM
warminwisc's Avatar
warminwisc
Default Key Reprogram
I know a new SmartKey can be reprogrammed to replace one that is lost and the blade cut to match. Can a key be reprogrammed from one car to another or will there be an issue with the actual blade/lock cylinder being different. Can the blade be changed and recut? Thanks
Old Apr 27, 2013 | 01:04 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
no you can not reprogram a smart key.you need to order a new smart key.check a lock smith in your area for a price.
Old May 1, 2013 | 05:10 PM
warminwisc's Avatar
warminwisc
Thanks, yur right.
Old Jun 9, 2013 | 10:50 PM
fensterlip's Avatar
fensterlip
I'm using a Smart Key that will need a new blade. Some locksmiths have them. If you look near the foot of the blade you'll see a very tiny screw that needs to be removed to pull the old blade out. I had the blade cut before getting the key programmed. Before the programming we changed cars. So old blade in a new Smart Key.
I've heard differing answers on whether a Smart Key that has received the programming for one car can be reprogrammed for a new car. There is a bunch of self-programming info for keys on the forum. I've tried them and none of them worked for me.
Old Jun 10, 2013 | 04:36 AM
warminwisc's Avatar
warminwisc
Not sure what the question is but see post 2.
GabrielR
Jan 3, 2018 12:55 AM
senapeSC
Mar 14, 2013 12:15 PM
Roley954
IS - 1st Gen (2001-2005)
Oct 9, 2012 04:28 PM
mrbananas
Jul 26, 2012 09:20 AM
mdk77
Chicago Lexus Club
18
Apr 26, 2009 10:07 AM
