Replacing rear CV axle --- DIY possible????
Old Jan 31, 2013 | 11:27 AM
gomboy60's Avatar
gomboy60
Default Replacing rear CV axle --- DIY possible????
Hi all,
I just want to run this by those know much more than I do. There is a metal to metal contact noise issue on my car (2005 LS430, 26k miles) on rear driver side, every time trans is shifted from P to R to D to R, without any other sound or symptoms while once vehicle is running). I might be wrong but I am suspecting (and hoping) it is the rear CV axle. To make the long story short, do you think replacing the axle falls into DIY catagory???? My level of automotive skill is being able to replace a timing belt, water pump, brakes, rotor, wheel bearing and others. I know I cannot touch engine / trans mod or rebuilding.
Any input is well appreciated.
Thanks.
cy
2005 LS430, 26k
2003 RX300, 156k
1997 ES300, 247k
1012 Toyota Prius V, 22k
geoffpaint
Mar 10, 2015 09:03 PM
MyIS350G
Dec 3, 2012 07:14 PM
tomjode
RX - 1st Gen (1999-2003)
18
Nov 23, 2012 01:31 AM
emg2919
Mar 26, 2012 04:48 AM
JimsGX
May 29, 2009 02:14 AM
