is rear wheel camber adjustable?
Old Aug 24, 2012 | 08:57 AM
mywong23's Avatar
mywong23
Default is rear wheel camber adjustable?
just had a four wheel alignment done.
specs were just bit high for right rear wheel camber.
tech said there was no adjustment (other than bending the strut...)
just wondering if any others have encountered the issue?
tia,
mike
Old Aug 24, 2012 | 09:12 AM
waijai's Avatar
waijai
There are 3 different length rear lower camber arms available from Lexus. The longer arm increases negative camber. The shorter arm increases positive camber. There are also fully adjustable arms from various companies such as Nagisa, T-Demand, Megan, etc.
Old Aug 24, 2012 | 10:15 AM
C8V6C's Avatar
C8V6C
If it helps, i priced the Megan adjustable ones at $275 shipped from a vendor. Not sure where else would be cheaper, but it gives you a baseline
Old Aug 25, 2012 | 04:52 PM
wopdud's Avatar
wopdud
No stock rear camber adjustments. 2003 LS430 UL
Bocatrip
Feb 17, 2022 02:02 AM
esonu
Suspension
May 31, 2019 09:14 AM
Lanceezy
Suspension and Brakes
Dec 2, 2012 11:26 PM
671IS250
Jun 13, 2011 10:28 PM
VinnRock
IS - 1st Gen (2001-2005)
Aug 22, 2009 01:02 PM
