I have a 2001 LS430. I figured it is 4.3 liter motor.
Since the Lexus is the top of the Toyota lineup are there other models of the Toyota that share the same motor?
Thank you.
If my memory is correct, the 4.3 was never in a Toyota model. The Tundra and LandCruiser came with the 4.7 V8, then the 5.7. The 4.7 will go down as one of the most bullet proof engine Toyota has ever produced. Minus the 18, 20 and 22R engines.
pretty sure that title goes to the 2jz-gte... a stock motor than can handle over 1000 hp, and will run for hundreds of thousands of miles even making moderate (double the stock output) power...
