'Fixed' Mirrors
Old Mar 27, 2017 | 03:05 PM
Reyes's Avatar
Reyes
Wow, I wish I would've read this post years ago. Thank you Akinsm for the fantastic information. Worked like a charm. I started with my passenger side mirror since it was the busted one. I'm definitely going to finish the job by bolting down my drivers side too!
Old Jun 10, 2018 | 12:17 AM
BCT's Avatar
BCT
Originally Posted by karasdad
BTW, I had used a 8 inch plastic tie wrap and secured the mirror to the base and kept it from rotating out 180 degrees and it worked for several months until my mechanic fixed it. It wasn't as obvious as you might think and nobody ever noticed it and you can't see it from the driver's position.
Sorry to reviving this old thread. I think I have the same problem. My driver side mirror rotate pass its stop position. Where do you apply zip tie? Just on the outside? I may need a temporary solution while trying to understand how to fix this permanently.
Old Oct 30, 2019 | 08:27 PM
BuddyWeh's Avatar
BuddyWeh
Default Power Mirror Over Extending
I clipped the dark green wire like the photo indicated and my problem was solved. Great Post!
Old Jun 24, 2021 | 11:44 AM
mrboca's Avatar
mrboca
Just make a small hole at the back of the mirror assembly and put a screw to anchor the zip-tie to stop the mirror assembly moving.
pinkoos
NX - 1st Gen (2015-2021)
13
Jul 9, 2015 02:57 PM
0l33l
Jan 20, 2007 03:04 AM
T0ked
Oct 5, 2004 06:03 AM
HoleinOne
Dec 11, 2003 04:44 PM
