Suspension Parts to Change
Hey everyone. I am going to be working on the brakes on my car fairly soon and I was wondering what parts of the suspension I could change out for a better ride. I am looking for things that are relatively easy to replace and parts that just wear out over time. Any thoughts on what to tackle?
Thanks!
Thanks!
In addition to the brake pads make sure you get the fit kit which includes some small brake hardware pieces, these along with proper greasing will keep the brakes quiet. The part of the suspension that is most likely to fail is the rear lower control arm bushing, it is oil filled and can tear and leak, resulting in some noises. Unfortunately the entire lower control arm needs to replaced as one unit in this case. Ball joints are also easy to access so check those while you're at it.
Deathrow23
Jul 24, 2015 05:05 AM
ReeM
GS - 1st Gen (1993-1997)
May 31, 2011 06:20 PM
Mr Jokster
Suspension and Brakes
Sep 24, 2009 11:06 AM
