Replacement MAF
Old Jan 30, 2012 | 08:35 AM
lyles3's Avatar
lyles3
Default Replacement MAF
For those who have replaced their MAFs, which brand did you use? Advance Auto lists a Denso 197-6030 for $133. I can acquire the Lexus 22104-22010 through Sewell for $131.50. On Amazon, there is a Beck Arnley for $78 and the Denso part number above for $82 plus $5.50 shipping. Any thoughts??
I am considering replacing the MAF. Performed cleaning back in Nov and it improved the stalls during acceleration significantly, but it is still not 100%.
Old Jan 30, 2012 | 09:15 AM
Jabberwock's Avatar
Jabberwock
Buy it someplace that allows easy returns. You can put the new one in and check it in 5 minutes. If the new MAF doesn't improve the symptoms, it would be good to be able to return it with minimal hassle.
Old Jan 31, 2012 | 07:58 AM
LSGarry's Avatar
LSGarry
In the best interests of disclosure...what the hell is an MAF?
Pardon my ignorance. =))
Ok, ok, I couldn't wait so I looked it up. Mass Air Flow According to Wiki here it is:
A mass air flow sensor is used to find out the mass flowrate of air entering a fuel-injected internal combustion engine.
Old Jan 31, 2012 | 02:16 PM
danxp's Avatar
danxp
have you tried cleaning out the throttle body? it worked wonders for me...
Old Feb 4, 2012 | 01:18 PM
lyles3's Avatar
lyles3
Mass Air Flow Sensor. Just replaced with Beck Arnley model from Amazon. $82 with next day shipping. Worked like a charm. So far, accelerates like it did when I first purchased.
Replaced plugs, TPS, and cleaned throttle body over a year ago. Hesitation on acceleration was still there until I cleaned the MAF with CRC MAF cleaner. Acceleration was greatly improved, but still not totally normal.
Old Feb 22, 2012 | 08:04 PM
ancdmd's Avatar
ancdmd
Is there a way to test the MAF sensor? I just cleaned mine and also cleaned my filthy throttle body. The car seems to idle a little smoother but a prior light engine knock now seems to be a little worse. I cleaned the MAF with electric parts cleaner.
Old Feb 22, 2012 | 09:57 PM
ancdmd's Avatar
ancdmd
I cleaned it again, after realizing I need to clean the inside part of the MAF and not just the temp bulb part. Definitely less engine knock now, but still doesn't seem perfect.
Old Feb 23, 2012 | 10:08 AM
GS4_Fiend's Avatar
GS4_Fiend
Make sure your throttle body is clean. To test the MAF sensor, probe the signal wire, do a snap throttle to about 4K+ RPMs, reading should be at least 4 V.
BTW, if your air filter is dirty, change it!
olsoncam
Aug 7, 2017 07:49 AM
MattJO
GX - 1st Gen (2003-2009)
Apr 4, 2017 11:18 AM
Allaretake
Jun 3, 2010 02:36 PM
gx470_05
May 24, 2010 10:28 AM
StarkoS14
Dec 22, 2009 11:37 AM
