Transmission Fluid
Old Jan 28, 2012 | 05:59 PM
tcr101's Avatar
tcr101
Default Transmission Fluid
Hi All,
I had my transmission oil flushed ~25k miles ago(total @ 214k). When I checked the transmission fluid level today (after the engine was warmed up and was in drive) the stick indicated I was on the low side. I put the cars on jacks to get a better look underneath and the entire bottom half of the transmission was covered in oil with a red tint to it. I am assuming this is the transmission's Type IV fluid and I am leaking oil somewhere..
So here are my questions..
1) Have any of you experienced anything like this? I realize the car is getting old (2001) and things like this happen, but I thought the 5 speed's were nearly bulletproof?
2) If something is leaking out of my transmission(not the gasket between the bottom to the transmission, I see it leaking down from above this part) Would I have to drop the transmission to fix it?
2b) If I do have to drop the transmission, I would have to take it to a shop.. Any ideas on estimates of how much this would cost? Am I looking at a $1000?
Thanks!
Old Jan 28, 2012 | 06:40 PM
NewLexus11's Avatar
NewLexus11
I know to remove the trans at the dealer pays 8hrs labor for a RWD vehicle. I would recommend trying to jack the car up and see if you can pinpoint the leak the best you can before resorting to just dropping the trans.
Old Jan 30, 2012 | 12:29 PM
GR6RR's Avatar
GR6RR
^ do what he have said, get under there and pinpoint the leak....
Check all the drain plugs, make sure their all torqued down to spec.
Old Jan 30, 2012 | 02:37 PM
LS430Lexus's Avatar
LS430Lexus
Had a similar problem in my wife''s Honda. We pinpointed leak to the gasket by using a dye. You might want to ask about this.
Old Jan 30, 2012 | 08:06 PM
tcr101's Avatar
tcr101
thanks for all the advice, I will have the car lifted again on Saturday and report my findings for others that might have this issue.
GSpearlwht
Performance
Mar 18, 2019 12:18 PM
OldLs400
18
Aug 5, 2018 07:30 PM
Fiend
Jan 8, 2017 07:10 PM
ontoy
Apr 16, 2009 09:27 PM
Limca3
Maintenance
Apr 19, 2003 08:39 AM
