HID Ballast Replacement
Old Dec 21, 2011 | 01:42 PM
dflanigan's Avatar
dflanigan
Default HID Ballast Replacement
Hello all, has anyone replaced their drivers side HID ballast? Mine went bad last week and I have no idea how to change the ballast. I'm pretty sure it is the ballast because I took the bulb out of the drivers side and it worked fine in the passenger side. BTW when the light went out it didn't flicker or go yellow or anything, just OUT. Thanks for any help you can offer.
Dan
Old Dec 21, 2011 | 11:20 PM
anlexls430's Avatar
anlexls430
Hi Dan
I had just the same thinking and the conclusion last year with my LS 2001. The bad bulb worked fine in the other side due to perhaps "different ballast voltages". I only put in the new bulbs and all worked fine so far.
Antero
Old Dec 22, 2011 | 05:16 AM
dflanigan's Avatar
dflanigan
I forgot to mention that i did buy a new bulb also and that didn't work either. Nor did the passenger bulb work in the drivers side.
Old Dec 22, 2011 | 07:56 AM
votru's Avatar
votru
Try to see if you can access the ballast via wheel well liner since ballast underneath the headlight otherwise removed the front bumper.
Cpartipilo
Jul 28, 2017 11:24 PM
hypervish
Jul 10, 2016 01:51 PM
Vibes63
Sep 6, 2012 03:47 PM
mrcrx28
General Classifieds
Jul 7, 2006 10:50 AM
SC300TURBO
Jul 24, 2002 03:07 AM
