LS430 Nav sporadic malfunctions
Old Sep 12, 2011 | 12:43 PM
OPLexus's Avatar
OPLexus
Default LS430 Nav sporadic malfunctions
My navigation system is on the fritz. When I go to enter a destination into the ADDRESS area it accepts all the input in the touchpad fields. But when I touch ENTER it no longer (as it usually does) goes to the searching progress display, but instead returns to a now darkened DESTINATION window that has the buttons for ADDRESS, MARKED, PREVIOUS DESINATIONS,POINTS of INTEREST etc. I have tried turning off the car and then restarting in the hopes of rebooting the nav computer to solve the issue. The I ACCEPT disclaimer appears, I accept, and then the current location map is displayed correctly. However when I press the DESTINATION button on the nav cluster, the darkened DESTINATION window displays again offering no active buttons from which to choose. If I drive for a period of time leaving the darkened window displayed as I do it eventually comes back up illuminated with available options. Failing disc drive? Short in the central communication wiring harness? Experts got any ideas??
Last edited by OPLexus; Sep 12, 2011 at 12:58 PM. Reason: typos, not clear enough in communicating problem
Old Sep 12, 2011 | 05:52 PM
yuri.ber's Avatar
yuri.ber
Try unhooking a negative cable from the battery for 30min. This will reset you navi.
Be advised, you will lose all your marked points, destinations, radio stations etc.
Old Oct 3, 2011 | 04:16 AM
Sweetdaddy's Avatar
Sweetdaddy
Did you update the navigation system?
aliga
Nov 22, 2018 02:38 PM
vipermann1
Nov 28, 2011 06:20 PM
TestnDoc
Oct 12, 2004 05:02 PM
