Wheel advice
Old May 22, 2011 | 03:28 PM
JBLover's Avatar
JBLover
Default Wheel advice
So this is my new Lexus. It is an 05 ML. I have Megan coilovers to install, tints are scheduled, window deflectors in shipped, and I have a badgeless grill. I am just wanting some wheel advice. I am thinks 5 spoke or mesh wheels and 20". I am hoping less than 3k for wheels and tires. Closer to 2.5k would be more ideal. Any help would be awesome.
Old May 22, 2011 | 04:27 PM
caddyowner's Avatar
caddyowner
You should be able to sell those 18" chrome wheels to another member (carguy..) Heck, I may even be interested to replace my scraped wheels. That will help defray the cost of new wheels / tires.
Don't forget to get some cheap painted 17" winter wheels and tires.
Old May 22, 2011 | 04:33 PM
dejavu157's Avatar
dejavu157
for 2.5k u can get pretty nice wheels
Old May 22, 2011 | 04:44 PM
CarGuy89's Avatar
CarGuy89
I would definitely be interested for a swap. If you do get 20s, you'll want some OEM 17s for the wintertime. I'm looking for a set of OEM 18s.... Plus you're in IL so you're not too far away from me.
BTW, I think you have a CL, not an ML. The burnt wood, plus headlight washers and extended leather say CL (which means you got radar cruise, door closers as bonuses).
Old May 22, 2011 | 06:38 PM
JBLover's Avatar
JBLover
I think you are correct about the CL, I have all the stuff you are describing. I have the auto door close and laser guided cruise. I could not remember if it was ML or CL. I have the mark levinson sound system. Love this car! So I can do a 20x10 on the rears and 20x9 on the fronts?
Old May 23, 2011 | 05:29 AM
caddyowner's Avatar
caddyowner
Good catch, carguy. I didn't notice he mentioned it was a ML cause I saw the wheels and thought of you. It is a CL and not a UL (from the pics) because it lacks the extra switches on the center console.
Old May 23, 2011 | 05:43 AM
CarGuy89's Avatar
CarGuy89
Originally Posted by JBLover
...So I can do a 20x10 on the rears and 20x9 on the fronts?
I've heard of people going those sizes. However, if you want a direct fit (ie no hub rings or fender work), you'll want to consider a wheel with bolt pattern 114.5 mm and an offset in the neighborhood of +40-45 (basically same dimensions as stock). What rims were you thinking of?
Old May 23, 2011 | 05:45 AM
CarGuy89's Avatar
CarGuy89
When I first saw the pics, I totally thought it was your car and was overjoyed to hear you were replacing your 18s...ah the disappointment that comes after false hope lol
Old May 23, 2011 | 10:50 AM
AznRacer's Avatar
AznRacer
first please edit your post and put the pics in row this way the thread doesnt seem to wide As for the wheels 20x9 with 30-35 offset and 20x10 30-up offset will fit good without any fenders modification.
Old May 23, 2011 | 10:56 AM
ItsRichie's Avatar
ItsRichie
Using the offset you stated above as a preference, what would be a good offset for wheels .5" wider? Similar?
Old May 23, 2011 | 01:51 PM
F.Brown's Avatar
F.Brown
JBLover, congratz on the new ride. It looks good and it looks like you have good things planned for your ride! I don't see you having any problems finding a nice set of wheels in your price range. Until I decided to go with custom paint on my WORK wheels, I was looking at rims and tires for under $3000!
Good luck and keep us posted!
Old May 23, 2011 | 03:04 PM
JBLover's Avatar
JBLover
Would WORK wheels be in that price range with tires?
Old May 23, 2011 | 04:03 PM
sojah's Avatar
sojah
take off about 6mm of offset for every .5" since .5" is 12.7mm...
Old May 23, 2011 | 07:38 PM
AznRacer's Avatar
AznRacer
It really depend if your willing to do a roll or shave on your fenders. I personally wouldnt go 20x9.5 up front if your not going to do any fender roll or shave because it will rub. But for the rear 20x10.5 +40-up is good
Old May 24, 2011 | 02:33 AM
ItsRichie's Avatar
ItsRichie
Thank you, you probably saved me some big buck$. I was looking at rims at size of 20x9.5, and wasn't planning to do any fender work. I have my eyes on a set of Work Varianza D3S from a local member
