2006 LS 430 Shocks
Old Apr 8, 2011 | 10:39 AM
svlexus's Avatar
svlexus
Its struts, Shocks dont have the spring mounted on them.
Old Apr 8, 2011 | 11:11 AM
Bon's Avatar
Bon
It's coil over shock. A strut includes a steering means. The LS does not do this.
Old Apr 8, 2011 | 12:02 PM
scottgolf's Avatar
scottgolf
svlexus, just look at it. its a double wishbone type front, a strut is a load bearing piece. with a double wishbone you have no loadbearing on the shock. Bon is right, a strut includes a steering means. This is a shock. Struts are on the es line.
Yes bmws use struts on the 3 series and that is why in a corner they loose there alignment. front engine cars with struts is not a good idea. on mid or rear engine it is ok (but still not as good as a double wishbone) because you can steer with the throttle and the car will still stick.
Plus struts are rough riding. the ls couldn't ride like it does with a strut system.
Old Apr 8, 2011 | 03:52 PM
Muti007's Avatar
Muti007
Originally Posted by scottgolf
Yes bmws use struts on the 3 series and that is why in a corner they loose there alignment. ..............
Wait, what?
Old Apr 8, 2011 | 09:45 PM
svlexus's Avatar
svlexus
You are talking about macpherson struts, these things are still struts, thats what lexus calls them.
Old Apr 8, 2011 | 11:08 PM
scottgolf's Avatar
scottgolf
svlexus - if you want to call them struts thats ok with me, but a strut is a structural piece, also a strut has a means of turning. the ls does not have struts, the es does. notice on the es how there is no upper wishbone for support.
Multi007 - with a mc phearson strut the contact patch does not stay the same in a corner. It becomes much smaller. The double wishbone is far better at holding the camber in a corner. Don't take my word for it, just ask a race driver or mechanic. They will all tell you. This is not just my opinion, its a fact. The only advantage of a strut system is that it is light weight. in a rear or mid engine car its not so bad, but all in all its a bad idea. They are a cheap way of doing things. You can't adjust a strut suspension like you can a double wishbone. This is the only real big drawback to the 3series.
Old Apr 8, 2011 | 11:12 PM
svlexus's Avatar
svlexus
Its semantics, lets call them marshmallows and burn them on a fire.
Old Jul 16, 2011 | 10:59 AM
garose1's Avatar
garose1
I have a 2004 LS 430 and i think my strut need replacing what is a good price. parts and labor,
Old Jul 16, 2011 | 02:22 PM
davelex's Avatar
davelex
The LS uses double A arms with coil over shocks. This could be called a strut but it's not a McPherson strut where, as pointed out above, the strut provides the upper steering pivot point.
The double A arm design is generally, GENERALLY, considered a more sophisticated and refined arrangement as it can be designed to avoid some of the compromises of the McPherson strut suspensions.
wmbinford
Feb 4, 2016 08:33 AM
SteveM
Jun 29, 2010 05:14 PM
can'tdrv55
Suspension
Jan 6, 2010 05:59 PM
psls400
Feb 16, 2005 11:56 AM
rd8a
Jul 12, 2002 06:04 PM
