Rear Shade issue
Old Feb 1, 2011 | 02:35 PM
dtaylor's Avatar
dtaylor
Cool Rear Shade issue
My rear shade functions fine. Problem is the plastic cord that holds the screen to the top horizontal frame sticks out on one side (DS).
Does anyone know how to fix this? Looks like I'll first need to remove the rear shade assembly to attempt to re-stuff the cord??
Anyone ever experienced this condition? Fixed it?
Old Feb 1, 2011 | 03:34 PM
m3nv's Avatar
m3nv
Can you not "stuff" the cord back in while the shade is up?
Old Feb 1, 2011 | 05:35 PM
HiloDB1's Avatar
HiloDB1
Have not experienced that problem. But I have removed the sun shade before. Its not all that difficult to do but its not fun and takes some time.
Old Feb 2, 2011 | 09:32 AM
CG lover's Avatar
CG lover
mine has a short piece (3") of the plastic cord they used for the install,, guess they forgot to clip it off,, does not bother me though,,
Derry
Old Feb 2, 2011 | 11:41 AM
dtaylor's Avatar
dtaylor
Mine looks like the screen has some slack in the far upper drivers side, and an equal length of plastic cord hanging out from the passenger side, so it apparently isn't extra untrimmed cord.
Stuffing or feeding it back seems impossible from the fully stretched, or "up" position. Perhaps I can take the whole assembly out and fix it, but I wanted to avoid that if at all possible.
Any other ideas certainly welcome....
Old Feb 2, 2011 | 01:37 PM
HiloDB1's Avatar
HiloDB1
Good luck with that without pulling it completely out. There is always tension on the mesh from the spooling mechanism in the shade.
Old Feb 2, 2011 | 02:07 PM
dtaylor's Avatar
dtaylor
That's what tells me I need to pull it to fix it.....bummer
Old Feb 2, 2011 | 02:53 PM
jayclapp's Avatar
jayclapp
I just noticed the same thing on my 04 UL last week. A plastic rod sticking out of the right side about an inch. It wasn't there the week before, because I was waxing the rear window chrome trim.
With the screen up I just reached in and pushed the rod back into place. Went in easily and I'll just keep an eye on it.
Suggest you try this first.
Old Feb 2, 2011 | 04:24 PM
daddykay24's Avatar
daddykay24
That plastic rod can be pushed back in. I have done it on mine give it a shot
Old Feb 4, 2011 | 06:57 AM
dtaylor's Avatar
dtaylor
Will do boys. Thanks.
Old Feb 14, 2011 | 02:15 PM
garybow's Avatar
garybow
My rear shade was inoperable when I purchased the car used with 35K miles on it. The rod was missing, and the dealer said they would have to replace the whole assembly -- $1200 for parts plus labor. Car out of warranty, so I used nylon ties to lash the screen to the frame. $.30 cens parts and no labor. Works fine.
Old Feb 18, 2011 | 08:49 AM
raffles's Avatar
raffles
I have experienced this problem a few times over 3 years. It's simple to just feed the white plastic dowel back into the shade. I had thought about putting a drop of crazy glue on the tip but as its not a big issue to rethread things I didn't bother.
HiloDB1
May 20, 2018 07:25 PM
nicklausw
IS F (2008-2014)
Oct 5, 2016 10:07 AM
kodibad
Apr 5, 2014 09:55 AM
MIA IS250
Dec 1, 2012 01:36 PM
INTMD8
Jan 26, 2010 09:06 AM
