Rear camber adjustment
Old Mar 19, 2012 | 01:03 PM
  #271
waijai's Avatar
waijai
Originally Posted by dalarainc
I have a Megan Racing Camber Kit and coil overs I have been playing with the adjustment for a while but I'm still experiencing rubbing on the rear wheels, I'm almost out of adjustment and I think I'm just going to change the wheels all together from 20x10 to 20x9.5
I experienced this. The more you increase negative camber with the lower arm, the more the caster changes. The rear wheel will push forward causing it to rub around the 9-10 o'clock position if you are looking at the drivers side rear wheel. To recenter the wheel, you need the rear traction rods.
It's been a pain in the butt and a real learning experience, especially with my aggressive wheel setup.
Old Apr 20, 2012 | 08:58 AM
  #272
waijai's Avatar
waijai
bump for update from Figs
Old Apr 20, 2012 | 12:40 PM
  #273
Celsior21's Avatar
Celsior21
Will, any chance you know how much degree can you max the megan camber arms before needing the traction arms to recenter the wheel?
Old Apr 20, 2012 | 02:35 PM
  #274
Mr.Doback's Avatar
Mr.Doback
i think its anything past around -7*+
Old Apr 20, 2012 | 02:44 PM
  #275
waijai's Avatar
waijai
When I had it set to -5 degrees, my rear wheels were off center already.
Old Apr 20, 2012 | 02:50 PM
  #276
waijai's Avatar
waijai
Well, let me add that the wheels were off center enough to cause rubbing, but I'm running 20x11 +12 in the rear. For someone with a less aggressive setup, it may not be enough to cause an issue.
Old Apr 20, 2012 | 03:53 PM
  #277
Celsior21's Avatar
Celsior21
It was pretty close for me as well running 20x11 +19. I was planning for a little more camber just to get the panel sitting between lip and tire. I'm thinking around -5 camber would clean things up. But I may need traction arms as well. Hoping FIGS would have something by now. But I've given up on that.
Old Apr 23, 2012 | 01:00 AM
  #278
FIGS's Avatar
FIGS
The Maker
Don't give up quite yet. Hoping to have about 7 sets welded up next week. We lost the tabs in the shop move so that was another setback. I hired another fabricator just to do these. So I should be able to release the front, toe and rear links in that time
stay tuned.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old May 4, 2012 | 02:21 PM
  #279
06~ULTRA's Avatar
06~ULTRA
im also rubbing at the 9'clock(driver) & 3'clock(pass). thats with a 10.5 +20 and -4 camber...so, it seems as the traction rods are a must have with the camber arms. this is with the megan racing set up.
Old May 4, 2012 | 02:27 PM
  #280
waijai's Avatar
waijai
Thinking of selling my wheels and running natural camber, so I might have my suspension arms up for sale soon if anyone is interested.
Old May 4, 2012 | 02:30 PM
  #281
06~ULTRA's Avatar
06~ULTRA
did you get the traction arms^^^
Old May 4, 2012 | 02:54 PM
  #282
waijai's Avatar
waijai
Yeah I've got traction, toe, and camber arms in the rear.
I also have a set of Nagisa Auto front upper control arms.
Old May 4, 2012 | 04:11 PM
  #283
Celsior21's Avatar
Celsior21
How much camber were you running Will? My plan is to go with traction and camber arms in the rear since i am not planning to go beyond -7 degree. How much are you planning to sell each item for? I may consider them. Also are you running and lowering blocks?
Old May 5, 2012 | 07:20 AM
  #284
waijai's Avatar
waijai
I was running -6 to fit the rear wheels. My alignment was on point, but the wear I've been experiencing is just unacceptable. I'm not sure if the soft factory air suspension is a factor, but I have a set of AirRex air struts sitting here waiting to be installed.
Yes I have lowering blocks front and rear.
I think my plan is to get fender work done, so I don't have to run so much negative camber for wheel clearance.
Old May 8, 2012 | 09:29 AM
  #285
06~ULTRA's Avatar
06~ULTRA
^^^pm'ed^^^
