what is the difference; standard/high/low disk wheels
Old Nov 30, 2010 | 01:39 PM
sojah's Avatar
sojah
Default what is the difference; standard/high/low disk wheels
like the title says, what is the difference between standard high and low disk wheels?
Old Nov 30, 2010 | 03:14 PM
waijai's Avatar
waijai
Clearance for brake caliper.
High disk offers the most clearance and is usually needed for cars w/ big calipers. (Least lip)
Standard disk offers some clearance.
Low disk offers the least clearance. (Maximum lip)
Old Dec 1, 2010 | 04:46 AM
sojah's Avatar
sojah
so if i have to buy 2 new rear wheels for example and i know the lip is like 4 inches so looking on the wheel size chart at this link here i find my wheel size at 20x10.5 +29 offset (and this appears on the standard disk list) so i can only assume that it is a standard disk. my plan is to go with a 20x10 +23 since this seems to give the same 101mm lip size so i can run a slightly narrower tire and still have the same lip size. so when and if i order these 2 new rear wheels is this the one that should work?? thanks waijai and other,,,
Old Dec 1, 2010 | 07:15 AM
Infamous 1's Avatar
Infamous 1
As far as your rear wheels, you should be ok. Usually the concern is with the front brake setup.
Old Dec 2, 2010 | 02:06 PM
m32's Avatar
m32
Are you keeping your stock brakes in the rear? If so, you should be fine with either setup
Edwin
Old Dec 2, 2010 | 03:02 PM
sojah's Avatar
sojah
Edwin
i have no plans on upgrading the brake calipers on this car at this time
thanks all for the input.
BIGGZ
Wheels, Tires & Brakes Forum
Feb 14, 2021 10:34 AM
darick12
Apr 14, 2011 04:41 AM
ILOVEGIRLS
Mar 31, 2007 02:30 AM
pimpluxGS
Dec 25, 2004 11:15 AM
Lettuce
31
Jun 4, 2004 07:19 PM
