next DIY write up ??
Old Sep 14, 2010 | 03:33 AM
RomanTPA's Avatar
RomanTPA
Default next DIY write up ??
I been a good boy last month and actually saved some money
Now Im thinking about doing another mini-project.
What do you guys think I should do next?
Old Sep 14, 2010 | 04:43 AM
caddyowner's Avatar
caddyowner
Lowered with snow tires on 16" steel wheels would be wrong on so many counts.
Old Sep 14, 2010 | 04:48 AM
RomanTPA's Avatar
RomanTPA
LOL, I said mini-project.
Im in FL, other than snow flurries with iced roads (last winter) it havent snowed here in about 25 years. Not even sure if they sell snow tires here. If they do.. I wouldnt even begin to understand why.
BTW, My nissan 240sx (lowered 4" with full Origin body kit) had 15s w/snow tires on it couple years back when i went up to SC.. It def looked.. well odd?
Old Sep 14, 2010 | 06:57 AM
DDLexus's Avatar
DDLexus
Roman, can you summarize the work you've done to this point?
Old Sep 14, 2010 | 08:36 AM
RomanTPA's Avatar
RomanTPA
LED HID ML CAM NAV WAX TINT
some other stuff
Old Sep 14, 2010 | 09:34 AM
StanVanDam's Avatar
StanVanDam
Just brainstorming here.. I don't think there are full pictorial DIYs for coolant change, differential oil replacement, pre-2004 ML nav override switch, LED door sill install, front and rear rotor replacement, air to non-air suspension conversion, spark plug change, fuel injector change, throttle body cleaning, fuel cap gasket change, sunroof track lubrication, the little lights inside the coin tray/suspension/ECT/height switches... maybe even wiper blades?
Old Sep 14, 2010 | 09:39 AM
caddyowner's Avatar
caddyowner
I haven't seen one of these cars with a continental spare tire kit...
Old Sep 14, 2010 | 10:41 AM
DDLexus's Avatar
DDLexus
DVD in the headrests
Old Sep 14, 2010 | 05:48 PM
RomanTPA's Avatar
RomanTPA
coolant change, differential oil replacement, spark plug change, fuel injector change, throttle body cleaning, fuel cap gasket change,my car has full 90k service done 4k ago
pre-2004 ML nav override switch. that is in one of my write ups
LED door sill install, custom made by you or ordered online?
front and rear rotor replacement, i will be doing that soon my front are warped
air to non-air suspension conversion, def not a small project
sunroof track lubrication, ill look that up when i get a chance
the little lights inside the coin tray/suspension/ECT/height switches... done in one of my write ups
maybe even wiper blades? how hard can that be? ill do it when mine go out
Old Sep 14, 2010 | 07:39 PM
REV-01's Avatar
REV-01
i know alot of peeps want the fog light rewire. may be you can do that
Old Sep 14, 2010 | 10:07 PM
Gil Smash's Avatar
Gil Smash
I vote rotors, one of mine is warped as well.
Old Sep 14, 2010 | 11:12 PM
FinnLS's Avatar
FinnLS
I did my front rotors abt 5k ago.
Was really a piece of cake. Didn't have time to take any pictures.
Few pointers though:
- As the repair manual states, you have to replace the caliper bolts with new ones.
- Remember to get a 8mm (if I recall correctly) bolt to get the rotor off if it is stucked. There is a small hole for the bolt in the rotor. You can try the bolt on the new rotor to
get the right size.
- Have a piece of rope to hang the rotor up when you get it off. I used the upper wishbone to tie the rope to.
- I used C-clamps and the old pads to push the pistons in.
- I had to remove abt. 20cc of break fluid after pusing the pistons in
Otherwise it is almost like pad replace.
I suppose the rear rotors are more tricky due to the parking break.
So I vote rear rotors.
Old Sep 15, 2010 | 03:02 AM
RomanTPA's Avatar
RomanTPA
i dont have that much money to spend, bc TVs needs somekind of player and thats more $. prob about $500-700 for a dicent install
what do you mean by the fog light rewire?
not true, in 70% of the cars is just an extra cable that goes to the caliper.
on about 20% it is a second brake (drum) on the inside of the rotor
and on about 1% it is a second caliper on the rotor
by the looks of it, its just a cable that goes to the LS430 rear calipers (see next post)
Old Sep 15, 2010 | 03:04 AM
RomanTPA's Avatar
RomanTPA
Old Sep 15, 2010 | 07:42 AM
DDLexus's Avatar
DDLexus
How about headlight tint? smoke or opaque vinyl.
