Engine Idle Low
Old Oct 6, 2013 | 06:13 AM
Lavrishevo's Avatar
Lavrishevo
Does the 430 have a idle air control valve like the ls400?
Old Oct 6, 2013 | 12:29 PM
Rezonans's Avatar
Rezonans
No, it has a step motor, in TB, computer controls the butterfly automatically.
Old Dec 27, 2022 | 04:10 AM
Artistic's Avatar
Artistic
3rd Gear
Originally Posted by GRAND_LS 4
Just to see if this is the famous low engine idle issue, does the problem fade away when you turn on the headlights and foglights? (or AC)
I have this issue & it's getting on my nerves. Turn on lights & idle fine. Switch off dips down like hell. Any idea how to fix this.
Old Dec 27, 2022 | 10:48 AM
TominPT's Avatar
TominPT
Did you clean the 8 idle ports on top of the throttle body, located under the small rectangular cover and held down by some fasteners?
If you Google LS430 Idle ports the first image hit shows what I am talking about...
Old Dec 27, 2022 | 12:59 PM
teaa's Avatar
teaa
i cleaned that the last time I cleaned my TB and I still have the same idling issue, bout 400rpm~
Old Dec 28, 2022 | 12:29 AM
Artistic's Avatar
Artistic
3rd Gear
Not all 8 ports, I saw 2 or 3 ports under the rectangular piece & sprayed some throttle cleaner into that.. But yesterday I observed oil in the back side of the throttle since I tried throttle replacement that didn't help
Lexus082
May 20, 2024 01:25 PM
MattLS400
190
Mar 18, 2021 03:28 PM
2jz
Jun 2, 2009 06:58 PM
truevietlu
RX - 1st Gen (1999-2003)
Jun 10, 2007 07:40 AM
