02 Rotors needed, suggestions
Old Dec 15, 2009 | 09:10 PM
justunme's Avatar
justunme
Default 02 Rotors needed, suggestions
Has anyone put others than OEM rotors on their 430 without having issues. I read some thread saying some brands actually warped after little use. I don't want drilled and slotted. I am considering the Magnum drilled rotors being sold by a company in Canada. Any thoughts or suggestions welcome.
Old Dec 16, 2009 | 06:05 AM
I6turbo's Avatar
I6turbo
Stick with OEM is my suggestion. They work and are most likely better quality than any aftermarket rotor you're going to get.
Old Dec 25, 2009 | 06:24 PM
FatCat23's Avatar
FatCat23
Default Great experience with after-market rotors
I put cross-drilled and slotted rotors on all 4 corners of both my 96 LS 400 and my 2003 LS 430 along with stainless steel lines.
I got everything from a place called R1. Their online store does not show their complete inventory for the LS. Call and ask them.
Stop times were reduced and most importantly brake modulation is MUCH better. I went with a more aggressive ceramic pad on my LS 430 and the first 3 stops require a noticeable increase in pedal pressure.
The only downside is a slight hum sound when applying the brakes hard.
I highly recommend upgrading the brakes, and R1 has all the pieces.
Old Dec 26, 2009 | 01:24 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
OEM is truly one of the best out there, they can easily last 160K with proper care.
Old Mar 3, 2010 | 01:17 PM
StanVanDam's Avatar
StanVanDam
Originally Posted by LSMAN
Wish I Had Done My Own Brakes. Total Cost With Pads And Rotors Turned Was $470.00.
Really Is Only An Hour Job After My Buddy Showed Me How Easy. The Rotors On The Ls Are A Monster And Do Not Need To Be Turned.
They Are Like Twice As Thick As Any Other Rotor I Have Ever Seen.
Lsman
I've read all of the rotor threads on the LS430 forums and the overall conclusion is that OEM is the best way to go. I trust that the Lexus engineers designed the brake system well enough. However, I can't say the same for the engineers who picked out the trunk struts..
Are you experiencing a specific braking problem that can be fixed with new rotors? Do you have the measurements of your rotors' run-out and thickness? How many kilometres/miles of use?
Old Mar 3, 2010 | 05:46 PM
I6turbo's Avatar
I6turbo
Originally Posted by LSin75075
I'm replacing the brake lines with braided steel because I've always hated how mushy the brakes are on the LS. I know it's a big luxury car, not a sports car, but I still hate the brakes.
You probably just need to bleed the brakes and possibly change the fluid. Contrary to popular belief, braid-armored lines don't really swell noticeably less than rubber-armored lines. The real purpose of braided lines is that they are more rugged and resist being torn away by flying track debris better than rubber armored lines. Unless the OE lines are in unusually bad condition, the difference you'll notice when you replace everything will be due to the bleeding and fluid change. I was told this by a racing brake engineer for Performance Friction several years ago, and I've actually tested it myself on a 300ZXTT. Everyone loves the look and placebo effect of the "braided stainless steel brake lines" though.
Old Mar 4, 2010 | 12:07 PM
I6turbo's Avatar
I6turbo
I remember back in the mid 90's when I bought my Akimoto air intake for my 1.6L Honda CRX... It added about 200 rear wheel wheel placebo HP to the car.
LOL
ak11
Wheels, Tires & Brakes Forum
Jul 18, 2013 12:29 PM
NaturalJZ
Jun 15, 2012 07:21 PM
Emilio253
Sep 21, 2010 09:15 AM
suloh
Maintenance
Oct 8, 2005 09:02 PM
brian3268
Oct 2, 2002 12:41 PM
