Offset Question.....
Old Sep 27, 2009 | 08:45 AM
olemanGS's Avatar
olemanGS
Default Offset Question.....
What is the lowest offset I go before I have to roll the fenders....with a 19x9 front and 19x10 rear...
Old Sep 27, 2009 | 04:57 PM
Red Square's Avatar
Red Square
fonts 235 with +30 and rears 265 with +32
Old Sep 28, 2009 | 07:50 AM
I6turbo's Avatar
I6turbo
I don't know, but I do know that it depends upon the tire sizes and ride height. NOT only on the offset and widths.
Old Sep 28, 2009 | 12:47 PM
sojah's Avatar
sojah
^ ^ ^ word, this is why you won't get a clear cut answer, because there are hundreds of possibilities.
Old Sep 28, 2009 | 05:24 PM
olemanGS's Avatar
olemanGS
That seems correct but within the ball park....225/35 fronts 245/35 rear and finger gap at the most......
Old Sep 29, 2009 | 05:18 PM
racinstyle's Avatar
racinstyle
Ive fit up to 19x9 + 26 19x10 + 26 with just a shave, then again thats with air suspension.
Old Oct 4, 2009 | 01:33 PM
olemanGS's Avatar
olemanGS
Default Wheels....
The rims i'm looking at are 19x9 +24 front and 19x10 +36 I will use 225/35 front and 245/35 rear....i have coilovers, Will I need to modify anything? I will be riding low....
Old Oct 4, 2009 | 06:56 PM
junjdm's Avatar
junjdm
if you are runnining those tire sizes....then you will be fine w/out modifying....
Old Oct 4, 2009 | 07:08 PM
olemanGS's Avatar
olemanGS
Default Your Car
Thank you...not to get off the subject but how much for that 01-03 to 04-06 swap.....I was looking to do that in time....
Old Oct 4, 2009 | 09:17 PM
junjdm's Avatar
junjdm
depends if your talking about just the front? or rear? or both? It can get expensive......only reason y i did it was cuz i got a good deal out of it. Otherwise a lot ppl say its not worth it.......but if its over time and you can collect piece by piece....and you can do the labor work on your own ( like I did ) it helps save $$$.....good luck....and post pics once you get the wheels...unless you don't mind saying what your getting
Old Oct 6, 2009 | 04:46 PM
Bryan858's Avatar
Bryan858
Wish I saw this before getting my rims. +46 up front with 245 tires look pretty flush so I am suprised some of you can run it the mid 20 offsets up front. I have +31 with 245 on the rear as well and it is alsp pretty flush. I haven't noticed any rubbing without any body mods other than an air drop but it is close. Next set of rims will probably be mid 20's in the rear with rolled fenders and low 30's up front with semi stretched tires. Would be nice to see some pics with noted offsets..
zebt66
Jul 20, 2009 04:54 PM
Lucid
Mar 2, 2009 02:38 PM
FIVEOHinNJ
Aug 13, 2007 07:52 AM
jbbnet
Wheels, Tires & Brakes Forum
Feb 7, 2003 12:29 AM
CaMsGS3
Jul 18, 2002 02:06 AM
