Front power outlet
Old Aug 29, 2009 | 04:27 PM
flyfl1pguy's Avatar
flyfl1pguy
Registered User
Default Front power outlet
Does some have a pdf file on how to replace the front power outlet?
i checked the driver side fuse and it is ok. Not sure if there is also a fuse outlet on the passenger side, but does anyone else here have the same problem. My radar detector is not working when i plug it in so I assume its the fuse, but when i checked the driver side fuse panel it is ok.
So now Im thinking of replacing the whole socket does anyone have a manual on how to replace power outlet ?
Old Aug 29, 2009 | 06:27 PM
jayclapp's Avatar
jayclapp
I think you need to ask this question to the IS Model Forum. There are threads on this Forum on removing the ash tray assembly which required some disassembly of the console, but that probably is applicable in your case.
Old Aug 29, 2009 | 10:48 PM
flyfl1pguy's Avatar
flyfl1pguy
Registered User
This is for my 01 LS430.Any help would be great!
THANKS!
Old Aug 29, 2009 | 11:35 PM
VQT's Avatar
VQT
I don't remember exactly where the fuse locate on top of my head but it is the fuse that you need to replace nothing else. Check the back of the owner manual, it will tell you where the fuse locate. The manual will spell out which number fuse for each fuction, the other page will indicate the fuse no. location and which fuse box.
The fuse box might be under ther hood. Sorry, I can't remember where it is but I finally found it after looking thru the owner manual.
Old Aug 30, 2009 | 08:04 AM
jayclapp's Avatar
jayclapp
THANKS!
My apologies for assuming you were asking for help on an IS.
I recently replaced my ash tray assembly with a replacement box from Sewell. The box has a power supply also. Replacing it required removing the console wood cover. The ash tray assembly has a cigarette lighter. Both units plug into the same electrical wiring. You might want to disassemble and see if the connections are OK. I also noticed that you can purchase a replacement cigarette lighter for around $60 or so if that is the problem.
Old Aug 30, 2009 | 08:54 AM
flyfl1pguy's Avatar
flyfl1pguy
Registered User
do you guys have any pdf file for removing the power outlet?
Old Aug 30, 2009 | 10:51 PM
VQT's Avatar
VQT
Have you check fuse no. 32? It's under the passenger's side kick panel (Page 487, 490 of the owner manual).
Old Aug 31, 2009 | 08:26 PM
flyfl1pguy's Avatar
flyfl1pguy
Registered User
THanks guys!~ it was the front passenger fuse that was busted! hehehe
I thought it was only the front driver side fuse so I assume that the whole outlet is busted.
Thanks for all the help!
Ktran1039
Apr 11, 2016 08:56 PM
PETERPHAN8
RX - 3rd Gen (2010-2015)
Sep 4, 2014 09:33 AM
ksan
Jul 30, 2014 05:28 PM
allenliu47
Nov 16, 2013 01:38 AM
barncat
May 7, 2012 06:51 PM
