Height sensors??(I think)
Old Jul 10, 2009 | 04:34 AM
sojah's Avatar
sojah
Originally Posted by JP2SEA
How would this work? Headlight beam pattern can be adjusted by manually by turning the adjusting nuts behind the head light, right? (just like what airtime did the write up).
I am having hard time lowering the light beam level with the adjusting nuts behind the head light. Can this some how work to lower the light pattern???
I'm lowered on DataSystem and head light is aimed so high up.... any suggestions? (I have '02 UL)
Bonafyd- I apologize to thread jack....but in need of help.
when my car is parked and turned on and headlights on i can raise and lower the light beam by adjusting the nut behind the head light on my 05 UL. not sure why yours isn't lowering properly. maybe is it possible that you just don't notice the slight slight lowering of the beam?? have you tried to park it about 20 feet behind a wall (on flat ground) and adjust the headlights around dusk time??
Old Jul 10, 2009 | 07:35 PM
JP2SEA's Avatar
JP2SEA
The nut will lower a bit but I want to lower more... I will try our method once my airsus behave this weekend. My front is jacked up all the way high and not self adjusting....sigh... more reason I want to go for an aftermarket air.
ciga
Sep 30, 2020 01:49 PM
LuxuryCar1
Jul 16, 2019 01:16 AM
mdanfas
Jan 26, 2015 04:06 AM
UGKkllr
May 3, 2014 07:19 PM
VA380
Maintenance
Oct 8, 2008 06:38 AM
