need help with hid's (fog)
Old Mar 8, 2009 | 07:01 PM
06~ULTRA's Avatar
06~ULTRA
Default need help with hid's (fog)
ok, so here it goes i purchased 3000k/35w hid's for my fogs. at first when i turned them on they took about 2/3 min's to illuminate in yellow. after being on for about 10 min's my passenger side would start turning a greenish color pretty much it was losing or not keeping its power (whatever). so, i e-mailed the seller and he sent me a new bulb free of charge which i very much appreciated but, after replacing the passenger side with the new bulb the drivers side wasn't fully illuminating. battery is good and i changed the fuse to a 20a.
my question is, does anyone know what the problem is? or does anyone have this same problem?
p.s. i bought the lights from v-leds which i know they are not cl sponsors....just wanted to buy all my led's and hid's from the same place.
Old Mar 8, 2009 | 07:17 PM
vbspunger's Avatar
vbspunger
Where do you get this kit, and what brand are the bulbs?
Old Mar 8, 2009 | 07:19 PM
vbspunger's Avatar
vbspunger
nevermind, I didn't read enough the first time
Old Mar 8, 2009 | 07:22 PM
Swagga82's Avatar
Swagga82
it might be the kit because i plugged my 20k HIDz right in and it powered right up so try to move the kit on both sides if its sill the same then it something with the car but if you switch the kit from one side to the other and the problem moves with the kit then you should know its the kit
Old Mar 8, 2009 | 07:24 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
HID's are usually a ON or OFF thing. A problem like the one you mentioned above usually means a problem with the bulb/ballast.
With so much after market HID manufacturers, so many vendors are buying cheaper brands to stay competitive.
Unfortunately, there isnt much to be done to fix it. Replace drivers side bulb and hope they last. Whatever you do, make sure your bare hands NEVER touch the glass part of the bulb.
Old Mar 8, 2009 | 09:19 PM
blacksc400's Avatar
blacksc400
Car Chat Moderator
yep, sounds like a cheap bulb.
This happened to my friend's 3000K yellow hids as well. He bought a cheap kit.
Old Mar 11, 2009 | 04:50 AM
sojah's Avatar
sojah
can you post up a pic of this weird color hid fog?? i would like to see it, thanks.
Old Mar 11, 2009 | 07:47 AM
adob0's Avatar
adob0
just as i was about to buy the same 3k/35w kit from v-leds...i read this post. i think i'll hold off for now.
but yeah, like sojah requested, let's see pics.
[threadjack]any one using the xenondepot kit?[/threadjack]
Old Mar 11, 2009 | 07:56 AM
sojah's Avatar
sojah
[threadjack]
i like your [threadjack] tags, i use my [sarcasm] ... [/sarcasm] tags occasionally but i didn't figure to many people got it!! you know??
[/threadjack]
Old Mar 11, 2009 | 12:50 PM
06~ULTRA's Avatar
06~ULTRA
heres a pic when i at first put the kit in.
Old Mar 11, 2009 | 09:17 PM
ChipGS430's Avatar
ChipGS430
I had the same problem with the light going green. It was my ballast that was going out.
Old Mar 31, 2009 | 05:52 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
These are pics of our H11 6500k Xtreme HID kit in the lows and our 9006 3000k HID kit in the fogs:
You can view more pics here:
http://www.kbcarstuff.com/Lexus_IS25...reme_s/188.htm
You can find our Xtreme HID kits here for more info:
http://www.kbcarstuff.com/HID_Kits_H...2001_s/216.htm
Steve
ksan
Feb 18, 2014 10:49 AM
mikedozz
Aug 25, 2010 03:28 AM
T4RBoarder
Feb 3, 2010 03:39 PM
Escobar
Apr 12, 2005 05:43 PM
