new LS owner questions
Old Feb 23, 2009 | 09:22 AM
BNR34's Avatar
BNR34
Originally Posted by LSGarry
Just curious BNR34, are you saying that with 18's your fuel economy is going to go down from 17's??
Yes.
If so why?
The 18s are heavier, both the wheels (bigger diameter) and tires (wider). Especially rotational weight, it takes more power to rotate the wheel/tire, making the car less efficient. Making it use more gas and making the car slower. So actually the LS430 with the 16's is the quickest and most fuel efficient.
Old Feb 23, 2009 | 09:26 AM
BNR34's Avatar
BNR34
Just curious BNR34, are you saying that with 18's your fuel economy is going to go down from 17's?? If so why?
Go find and read the MPG thread, guys running 16s/17s are getting 25~28 MPG, guys with 20s are getting 18~20 MPG.
I forgot to mention, the wider tires from the 18s increases the rolling resistance also, which decreases MPG.
Old Feb 23, 2009 | 10:14 AM
AlexusAnja's Avatar
AlexusAnja
Default Wider
The 18" is a direct bolt on. Advantage: Better traction/handling, more aggressive looks. Disadvantage: firmer/harsher ride, decrease fuel economy, more expensive tires.
Just curious BNR34, are you saying that with 18's your fuel economy is going to go down from 17's?? If so why?[/QUOTE]
I believe the OEM 18's, you'll be going from 225 to 235 (or 245) wide tires, so that alone will cause you increase road resistence/friction and lose MPG. Better for handling yes, but not for just plain rolling. I think you'll lose maybe 2 mpg tops, but more likely 1 mpg.
If handling is what you're looking for, going to 18 will help. If you like the 17, then just keep them. I have 17 for snow tires and 18 for summer, only because my LS came with the 17 and I didn't wan't to switch tires back and forth between seasons. Got 18 because I like them...
Old Feb 23, 2009 | 01:05 PM
LSGarry's Avatar
LSGarry
Originally Posted by BNR34
Yes.
I'll be damned...I never knew that. I did know about a wider footprint causing more resistance but not about the rotational weight. Thanks for the info.
Old Mar 22, 2009 | 02:06 PM
jeffbayne's Avatar
jeffbayne
jeffbayne, we have answered most of your questions, I got some question for you.
How do a 240k miles LS430 drives? Original engine and tranny?
Do you know how many times your friend replaced the air shocks?
Is the NAV screen still functioning? Everything on the car still works? Power door latches, laser cruise control.....etc?
Thanks.
i asked the previous owner about the air shocks- and he said they had never been replaced. So... for some odd reason (relative to what you guys have said) I have 240k on my air shocks. Seems like a lot, makes me happy (unless they go out soon )
Old Mar 22, 2009 | 04:11 PM
BNR34's Avatar
BNR34
No problem.
It is one factor why economy cars with tiny 14"-16" wheels with skinny tires gets better MPG. Look at all the cars that focus on fuel economy, all the Hybrids or cheaper economy cars, they all got small wheels with skinny tires.
Old Mar 22, 2009 | 04:13 PM
BNR34's Avatar
BNR34
wow, that is hard to believe. I appreciate you checking for me though
Dutchie101
May 23, 2011 10:17 AM
kg19989
Aug 9, 2010 09:57 PM
PremiumG
Jan 26, 2010 10:43 AM
BlackLexEs
Feb 1, 2005 09:04 PM
whiteboy
Jan 22, 2003 06:29 PM
