electric problems?????
Old Feb 18, 2009 | 01:26 PM
newday95's Avatar
newday95
Default electric problems?????
if i dont use my car for 2 day it wont stant,i changed the battery and the alterdator.i cant take it to the dealer because is cost a lot of $$$.some one else have the same problems???? and can give me a idea of what it is.thanks for your help.
Old Feb 18, 2009 | 06:12 PM
AlexusAnja's Avatar
AlexusAnja
Default Still doesn't work?
Dumb question, but after you changed the batter and alt. it still won't start after a few days? Does it crank over, or just clicks? Perhaps a bad starter could be at fault.
Or, better yet, just drive it every day so you don't go the "2-days" for it to die.
Old Feb 19, 2009 | 11:56 AM
rkanazawa's Avatar
rkanazawa
Default Same Problem
Hello:
I am having the same problem but my '05 is still under the extended warranty so it is back at the dealership. I normally drive the car daily so don't have problems. It happened twice before and I had the battery replaced the second time. I left if for three days the day after having the 60k service done and tried to crank and the battery was totally drained. Their suspicion is that there might be a short somewhere in the system.
Old Feb 22, 2009 | 01:41 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Originally Posted by rkanazawa
Hello:
yes, usually there is a device causing a leak/drain within the system. I hope this is sorted for you, as sometimes it can be a nightmare diagnosing these types of problems.
Old Feb 22, 2009 | 06:23 PM
big_blzr94's Avatar
big_blzr94
disconnect the negative battery terminal and put your test light on the cable end and the negative post of the battery. if ther is a draw on the battery with key off it will light up. if it is lite start taking out one fuse at a time until the light goes out (be sure to put the fuse back after checking circuit). once you have found the one that makes the light go out you must find what is on the circuit that has the open draw.
Old Feb 23, 2009 | 01:26 PM
newday95's Avatar
newday95
thanks i ll do that,thank you very much.
melbitoast
IS F (2008-2014)
Jul 10, 2013 01:17 PM
jxm
RX - 3rd Gen (2010-2015)
Jun 6, 2013 08:42 AM
mpbird
HS 250h Model (2010-2012)
Jul 31, 2010 03:27 AM
revan1000
Sep 2, 2009 04:42 AM
TampaBay
Nov 11, 2008 09:21 AM
