LS430 FM sound not continue.
Old Feb 6, 2009 | 02:47 PM
tpv2003's Avatar
tpv2003
Default LS430 FM sound not continue.
I have a Lexus LS430 2001. The FM has problem that sound is not continuously. It stop and go in seconds. Anyone know the problem please advise.
Thank you very much.
CD,AM,Navigation is ok.
Old Feb 7, 2009 | 07:16 AM
kenny b's Avatar
kenny b
Is yours on every station cause the same thing was happening to me on my 02. Only on one FM station. I pre-set the same station on the second mode or series of station settings on the radio and it seems to be fine on there. I know its not the fix you were looking for but hope it helps.
KB
Old Feb 7, 2009 | 07:27 AM
scottmcc's Avatar
scottmcc
It is most likely your FM antenna. Check to see that it is plugged in all the way or is not partially cut.
Old Feb 7, 2009 | 04:23 PM
playa3uhh's Avatar
playa3uhh
i had a temporary solution to this. When you are on a station and it "jumps" press the seek up/down button once and then go back to the station you were listening to. The jumping should go away. It's a quick and easy temporary fix.
Old Feb 7, 2009 | 04:38 PM
lexier's Avatar
lexier
Default FM filter
On the 2001 and 2002 there is a FM filter option. If you go to the
audio menu and find something that says "FM filter" or "AF" you then
can select to have it on or off. When it is in the "on" posistion, it
will cut out any weak FM signals. My dad had the same problem on
his 2002 and when it was turned off, it fixed the problem. Hope this
helps!
Old Feb 7, 2009 | 11:18 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
helps!
Thats exactly right. "AF" button should fix this.
DenSmith
Aug 13, 2018 08:57 AM
peggypwr1
Jun 13, 2015 02:50 PM
Jamimarti
Dec 19, 2008 09:48 AM
usermel
Maintenance
Sep 21, 2004 12:07 AM
