Water in headlight
Old Aug 29, 2008 | 12:25 AM
VQT's Avatar
VQT
Default Water in headlight
Has anyone ever have water in their LS 430 headlight?
How did you fixed it?
I guess new headlight housing is needed.
Thanks,
Old Aug 29, 2008 | 01:05 AM
GS3Tek's Avatar
GS3Tek
It's very common in the 2nd gen GS headlights.
If you're out of warranty, try some of these quick fix/band-aid.
Some simple fix (if not that bad) is using the hairdryer and heating it up.
Some have tried opening it up and resealing it with silicone.
One solution I remembered reading was an improper drainage-behind the headlights have drainage tube that can be block-or poor ventilation.
I can't remember exactly, but here's a starter. You can also use "foggy headlight". I used "condensation headlight":
https://www.clublexus.com/forums/sea...archid=2281037
Old Aug 30, 2008 | 12:37 AM
VQT's Avatar
VQT
Thanks GS3Tek,
My original search didn't help much, your foggy headlight suggestion help alot.
Old Aug 30, 2008 | 09:40 AM
GS3Tek's Avatar
GS3Tek
NO problem
If you found a fix, let us know.
Old Aug 31, 2008 | 06:57 PM
VQT's Avatar
VQT
Had to take out the air filter housing to get to the high beam light. Working on drying the light housing now. There is a lot of moisture in there...
I don't know where is the leak yet to seal it, but at least I know how to dry the thing now.
Old Aug 31, 2008 | 11:47 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Just put a layer of sealer on the edges of the headlight, thats usually where the leak starts.
And yes, i've had issues with my GS... they are legends when it comes to headlight moisture. Problem is, its such a pain to take the headlights off in the GS, because front bumper must come off.
Old Sep 1, 2008 | 02:18 PM
VQT's Avatar
VQT
Took me 4 times (30 mins each) yesterday using the blow dryer to clear the moisture off the passenger headlight on my LS 430.
What kind of sealer is good for this type of application?
Thanks,
Mar 26, 2018 10:56 PM
genaos11
Dec 2, 2011 12:08 PM
cupid0210
Apr 12, 2011 11:09 AM
2jztt
GS - 1st Gen (1993-1997)
Oct 11, 2007 05:48 PM
