Lugnut specs?
Old Mar 14, 2008 | 04:59 PM
bonafyd's Avatar
bonafyd
Default Lugnut specs?
Hey guys i just ordered some wheels for my ride and i need some help on lugnuts, i need to know the size/thread dimensions for the LS430? i want to order those diamond tipped lugnuts to set out my wheels.
Any help is appreciated.
Old Mar 16, 2008 | 08:43 AM
motohide's Avatar
motohide
All Toyota lug nuts are the same pitch and thread.
12mm@1.5 pitch
If you get open ended ones, it will work regardless of stud length. All Toyota passenger cars are the same spec thread. so just specifying TOYOTA/LEXUS/SCION will be fine. Only some SUV, and Trucks have longer studs so here you will need open end designs so it won't bottom out before it can lock on the wheels. Avoid 21mm head nuts if you are using wheels with narrow or deep bolt holes on the wheel as clearance for the wrench socket becomes very tight. And NEVER use OEM Toyota lugs on aftermarket wheels as OEM is a round head and aftermarket is almost always tapered head.
Mydogbella
IS F (2008-2014)
Feb 25, 2014 06:34 PM
zabone
Oct 22, 2013 10:24 AM
JETLEX
Wheels, Tires & Brakes Forum
Mar 7, 2013 10:15 AM
stw2046
RX - 3rd Gen (2010-2015)
Apr 25, 2010 06:57 PM
RICHYRICH
Jan 18, 2006 11:51 PM
