Converting Air Suspension Struts to Conventional
Old 09-09-07, 10:57 AM
mixednuts
mixednuts's Avatar
Default Converting Air Suspension Struts to Conventional
Just had my second set of front Air Suspension Struts replaced on my LS430. Question-is there a conversion kit available to switch to convential struts? These $1100 Air Struts are killing my pocket book. I've searched the internet and have only found kits for LS400's.
Old 09-09-07, 12:54 PM
Randy B
Randy B's Avatar
Default Sorry to hear that for you!
This is much the reason I sought out one without the adjustable suspension. The fixed struts in the Sport are just fine!.
Randy B
Old 09-10-07, 09:25 AM
bigcory
bigcory's Avatar
how much are OEM "fixed" struts?
Old 09-10-07, 06:19 PM
mixednuts
mixednuts's Avatar
Not sure how reply to the term "Fixed"! If you are referring to rebuilt units I have not seen any advertised on the internet for a LS430. New Toyota Air Struts are $1100 each!
Old 09-11-07, 06:50 PM
bigcory
bigcory's Avatar
by "fixed" i was refering to non air struts. What you would find on reg/sport models.
Old 09-11-07, 07:09 PM
mixednuts
mixednuts's Avatar
Have not found any "fixed" struts for a 2002 LS430. I find plenty for the LS400's. I have sent e-mails to several suppliers for these struts, but not received any replies as yet. The Lexus service department was of no help.
Old 09-11-07, 09:33 PM
bigcory
bigcory's Avatar
I guess i'm a little confused. Are yous saying the air suspension uses the same struts as a regularly equipped car?
Old 09-12-07, 06:13 PM
mixednuts
mixednuts's Avatar
Not at all! I want to replace the Air Struts with regular struts that come with LS430 without the Ultra Package.
Old 09-18-07, 09:32 PM
bigcory
bigcory's Avatar
So I ask again , how much for these fixed struts from a regular non UL LS430?
Old 09-18-07, 09:41 PM
IronCobra
IronCobra's Avatar
I don't know if it's possible but here are the costs:
48510-50130,STRUT Front SPORT PACKAGE: $76.71
48510-50120,STRUT Front NON-SPORT: $76.71
I'm sure you will needs the springs also:
48131-50130 OEM Lexus Front Coil Spring SPORT PACKAGE: $113.38
48131-50140 OEM Lexus Front Coil Spring ROUGH ROAD PACKAGE & SPORT PACKAGE: $131.35
compared to the Air Suspension
48010-50110 Pneumatic Front W/Shock Absorber Cylinder Assembly: $985.20
Old 09-19-07, 06:13 PM
kenttz
kenttz's Avatar
So you can put the struts from a regular LS430 into one that has the air suspension? I am just curious as I want to purchase a 04 LS W/ UL but wanted to know if the air suspension goes bad I can just put the reg struts on it instead of spending like 4k on replacing the air ride setup.
Thanks
Old 09-19-07, 09:34 PM
Evisu LS
Evisu LS's Avatar
I checked that out before we can just put on the aftermart coilover (like TRD , TOM's) to replace those Air suspension , anything is perfect fix except u can't adjust the height level and sport mode ..
Old 09-20-07, 12:27 AM
chek1234
chek1234's Avatar
Similar question here (don't mean to take over the thread or anything):
I have an 01 LS430 with Sports suspension and I can tell the ride feels the bumps in the road more than an 01 LS430 with Regular Suspension. I want to have the regular suspension. I want a smooth elegant Lexus drive. Can this conversion be done? Do I just replace the struts with the regular suspension one? Any approximate cost?
Old 11-16-07, 02:04 PM
b8b
b8b's Avatar
Did anyone determine if this was possible? Thanks in advance.
hippchip
06-26-19 11:00 AM
sgvlex
02-09-16 09:45 AM
gstromb101
08-13-14 09:45 AM
REV-01
05-31-11 06:34 PM
celsior 7
05-20-08 09:18 PM
Quick Reply: Converting Air Suspension Struts to Conventional
