Changing high mount brake light 2002
Old May 8, 2007 | 06:39 PM
rduncan265's Avatar
rduncan265
Default Changing high mount brake light 2002
Does anyone have instructions on how to change out the high mount brake light (center brake light, on rear window) of the 2002 LS 430?
Thanks
Old May 8, 2007 | 08:53 PM
cdnguy's Avatar
cdnguy
It's easy. The secret is that the cover shifts to the side, before it comes toward you, if you are kneeling in the back seat. When it comes off, the bulb holder will be exposed, and you need to take it out to remove the old bulb, and insert the new one. There are more detailed instructions around, I'll see if I can find them.
Old May 8, 2007 | 09:06 PM
cdnguy's Avatar
cdnguy
OK - found this from my earlier post.
Well, I finally figured out how to remove the housing. You have to move it 1/2" to the left, then lift it straight out. Then you can remove the connector wire, and the bulb assembly to replace the bulb.
Old May 8, 2007 | 10:30 PM
rduncan265's Avatar
rduncan265
Your instructions were perfect, thanks. Made it real easy.
Stango
Lighting
May 16, 2025 12:31 PM
xfea
Nov 14, 2013 06:48 PM
alextv
Maintenance
Oct 5, 2011 07:12 PM
saelee39
Oct 3, 2007 04:55 PM
cdnguy
Oct 24, 2006 08:04 PM
