Navigation DVD location in 2001 ls 430
Does anyone know the location in the trunk where I install the DVD to update my navigation system in a 2001 Lexus LS430? Any help would be appreciated BECAUSE the dealer wants to charge me over $100.
Thanks for your help in saving me and many others $100.
-Greg
-Greg
As you face the trunk, lift the cover to the right end bottom of the trunk; you will see the top of the DVD Nav unit. Remove 2 screws (make sure you do not drop them into the bottom of the trunk); lift the unit as far as you can; with the ignition power on press the eject button on the DVD Nav unit (on its front); the old DVD comes out; put in the new DVD; lower unit and replace screws; DVD loads itself; you are good to go!
[This is what should work - I take no responsibility for anything going wrong.]
(And yes, mail me the check the dealer was going to charge you
Good luck!
).Good luck!
Hi viskha,
Thanks for your time in Helping me & many others. As for the $100...I say for each person that has been helped by your post we send you $1 This could turn out to be long term residual income
Thanks..again!
Greg
Thanks..again!
Greg
BlueCrabby
Oct 12, 2019 09:55 PM
98cruiser
May 1, 2010 12:32 PM
