2001 ls430 transmission shift linkage leak?
Can anyone identify what this part is called or provide a part number. It’s for my 2001 ls430. It’s leaking from the transmission pan shift linkage area. Not sure if it’s a gasket, grommet or what it is. If it's a part please provide the part number and a how to. Any info would be appreciated. Thanks.
Are you losing a substantial amount of fluid or is it just wet in that area?
It appears to be the latter. It’s not uncommon for the pan gasket to leak a small amount.
Clean the area and gently tighten the pan bolts, then check back in a week to see if it’s still wet.
JJman
Nov 16, 2023 07:43 AM
