P1349 not going away!.
Old Mar 27, 2026 | 01:13 AM
3uzchiv's Avatar
3uzchiv
9th Gear
Default P1349 not going away!.
So I drifted a corner in my 2001 ls430 (wasn’t really a drift) then low oil pressure warning came on and car shut off seconds later. after that happened I’ve been having a p1349 code that just doesn’t go away I’ve replaced ocvs,actuators( timing tube cam gear assembly) and have done the vvt filter the vvt filter was indeed full of junk. I have done timing belt aswell only problem is p1349 haven’t got a bank 2 vvt malfunction or anything. What can be the cause of this code? Bad head or something? Haven’t heard a knock or tick so i don’t think it too bad but I wanna get rid of that code for Good
Old Mar 28, 2026 | 06:55 PM
indigofilipino's Avatar
indigofilipino
how did you diagnose the code? Are you using Techstream or just a generic OBD2 scanner?
Old Mar 30, 2026 | 12:47 AM
3uzchiv's Avatar
3uzchiv
9th Gear
Default P1349
just an obd 2 scanner
Old Mar 30, 2026 | 09:07 AM
intermec's Avatar
intermec
For some reason, most of the vvti code are on bank 1 for Toyota/Lexus
Did you replaced the part with aftermarket?
Were you able to clear the code?
I was a bit surprised to read that your vvti filter was full of junk. (honestly not expecting this)
Old Mar 30, 2026 | 09:09 AM
3uzchiv's Avatar
3uzchiv
9th Gear
Default 1359
parts were oem and filter was so gunked up
mphsatty
Oct 4, 2016 08:26 AM
mtuma5672
Jun 14, 2015 07:16 AM
empera
Jun 12, 2014 06:54 PM
mildawg
Jan 29, 2014 07:46 PM
02msmg3
Dec 13, 2010 11:47 AM
